Old 12-21-2012, 07:09 PM   #1
Help me select the correct inline fan for this fireplace project
I have a wood burner in my basement that radiated heat up to 80 degrees nicely, but the heat wasn't moving to the upstairs living area. I fabricated a heat shield to capture alot of the heat off of the wood burner. Here is a pic of it:
I capped off the far end and put a 6 inch piece of ducting and then hooked it up to a furnace blower just to see if the heat shield was effective at trapping the heat and funneling it to the ducting. Well, it works fantastic. I had the furnace blower pointed at the stairs and I was able to get the upstairs up to 77 degrees without having any type of ducting. Now, I need to get the heat upstairs. I cut a hole in the floor and inserted a register and ran 6" flex duct from the register in the rafters and down to my heat shield. It's approximately 16 feet of flex duct. I want to use an inline fan to connect the duct and the heat shield but I don't know what cfm fan I need. I want the fan to be strong enough to suck the air from the heat shield and blow it the 16 feet to the register, but I don't want to "over-fan" this project and wind up with a really noisy fan that isn't necessary.
I would welcome any suggestions on inline fans with 6" inlets & outlets and/or what cfm is necessary for this project. I was looking at the Vortex fans, but 450 cfm seems like overkill.
Thanks for all of your help!
-Paul
xpauliber is offline   Reply With Quote
Old 12-21-2012, 08:16 PM   #2
Roofmaster
sounds like a good place for a variable speed fan with a pot, no?
" A lot of men build things, and a lot of things fall down "
Old 12-21-2012, 09:17 PM   #3
Will a pot allow me to adjust the speed of the fan? That sounds like a great idea!
Any fan suggestions?
Old 12-22-2012, 06:05 AM   #4
An old Tradesmen
Hopefully, you have another hole in your floor for air to come down to the basement to replace the air your blowing into the upstairs. So you don't back draft the wood stove.
Any fan in the 100 to 150 CFM range should work.
Old 12-22-2012, 06:06 AM   #5
An old Tradesmen
Old 12-22-2012, 08:24 AM   #6
There's a wide open stairwell that is almost adjacent to where the register in the floor is. It should supply more than enough air back to the basement.
I'm wondering if I use a fan that is more than enough with a pot and then I have the ability to really crank it up if I want, but I can scale it back also?
Old 12-22-2012, 11:44 PM   #7
I am thinking of going with this fan:
http://www.htgsupply.com/Product-Gro...nline-Fan.asp#
And also getting the fan speed controller:
http://www.htgsupply.com/Product-Blo...ed-Control.asp
How to go about replacing fireplace surround? NewHomeDIYGuy Remodeling 9 01-26-2012 10:56 PM
What correct mix for building a stone foundation wall? & correct mix for stone fireplace. world travler Building & Construction 0 08-04-2011 07:39 PM
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 04:07 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
DV Fireplace Recommendation - Correct Forum? BigJimmy HVAC 2 01-06-2008 06:35 PM
