Help Me Replace A Cap - HVAC - DIY Chatroom Home Improvement Forum
Old 07-23-2010, 07:35 PM   #1
Help me replace a cap
My outside fan unit isn't blowing and after some research would like to try and replace the capacitor.
I spoke with one of the HVAC guys at work and he gave me two oval caps. One is 5uf and the other 7.5uf.
I removed the panel and my cap is rounded with 3 individual prongs instead of oval with 2 and it is 5uf. He told me that I could use the oval and just keep both...
I can't afford a tech to come out and look at it so here we are...
Which wires go where and can I keep both?
mburgess44 is offline   Reply With Quote
Old 07-23-2010, 07:54 PM   #2
An old Tradesmen
Rewards Points: 6,074
Pull the wire that is on the F terminal off, and put it on the new cap.
Then run a jumper from the C terminal of the dual cap. To the opposite terminal of the new single cap.
Old 07-23-2010, 08:46 PM   #3
On the new cap each prong has 4 sides.. does it matter which one I plug it up to?
So say my old round cap I pull the brown cord from B(f) and put it on A of the new cap. I then go from the new cap B to the old cap B?
I hope that made that clear.. sorry...
A B
[] [] new cap
A B(f) C old cap
Old 07-23-2010, 08:55 PM   #4
This might make more sense...
F cable is removed from the round cap and put on the oval cap -- any prong. Jumper goes from other prong on oval to old prong on round cap
Old 07-23-2010, 09:19 PM   #5
An old Tradesmen
Close.
The "F" cable gets put to new cap.
Then a jumper is ran from the C terminal of the old cap. To the opposite terminal on the new cap.
Old 07-23-2010, 09:25 PM   #6
Close.
Okay,
F cable is taken off the old cap and put on the new.... got that
A jumper needs to go from the old cap C terminal to the new cap opposite terminal of where the F cable went.
Here is my question.... isn't a cable already on the C terminal of the old cap? if I connect a jump to the terminal where does the old cable I remove go to>?
Old 07-23-2010, 09:42 PM   #7
An old Tradesmen
You don't remove any cable from the C terminal of the old cap. It should have an open spade left on it, for a jumper.
If it doesn't. then you run a wire from the contactor terminal that has the wire that runs to the old caps C terminal.
Old 07-24-2010, 04:42 PM   #8
Thanks for your help. I added the new cap today but it still didn't work... I guess I'll call the HVAC guy...
The outside unit is just buzzing...
Old 07-24-2010, 05:10 PM   #9
Look on the copper lines inside the AC for a small plastic cylinder with two wires coming from it. If it has a buttom on top push it. Fan went out would have tripped the high pressure switch, the cylinder, which needs to be reset.
Old 07-24-2010, 05:29 PM   #10
Is it inside the same section where my cap is? If so, the only plastic piece I see if the one where my inside wires go in and the cap is connected to prongs... no button there..
Old 07-24-2010, 05:36 PM   #11
An old Tradesmen
What brand and model number is your unit.
Old 07-24-2010, 05:50 PM   #12
google "manual reset high pressure switch" for pictures
Old 07-24-2010, 06:31 PM   #13
It's a Goodman 13 seer... I'll check on the model when the sun goes down. I've been stung by bee's twice today... ouch..
Old 07-24-2010, 06:49 PM   #14
Goodman GSH13
Old 07-26-2010, 10:45 AM   #15
I took the top off and can't seem to find it near the condenser either... is it possible that it doesn't have a high pressure switch?
Need Advice ASAP. New home, seller is paying to replace roof elpa Roofing/Siding 4 02-18-2010 08:03 PM
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 02:54 PM
replace galvanized pipe below kitchen sink? Jeremy Hillary Boob, PhD Plumbing 3 04-03-2009 09:39 AM
Carrier 58 PAV-repair vs. replace cczkcb HVAC 8 09-25-2008 01:57 PM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 10:40 AM
