-   -   Help me replace a cap (http://www.diychatroom.com/f17/help-me-replace-cap-76925/)
mburgess44 07-23-2010 06:35 PM
My outside fan unit isn't blowing and after some research would like to try and replace the capacitor.
I spoke with one of the HVAC guys at work and he gave me two oval caps. One is 5uf and the other 7.5uf.
I removed the panel and my cap is rounded with 3 individual prongs instead of oval with 2 and it is 5uf. He told me that I could use the oval and just keep both...
I can't afford a tech to come out and look at it so here we are...
Which wires go where and can I keep both?
beenthere 07-23-2010 06:54 PM
Pull the wire that is on the F terminal off, and put it on the new cap.
Then run a jumper from the C terminal of the dual cap. To the opposite terminal of the new single cap.
mburgess44 07-23-2010 07:46 PM
On the new cap each prong has 4 sides.. does it matter which one I plug it up to?
So say my old round cap I pull the brown cord from B(f) and put it on A of the new cap. I then go from the new cap B to the old cap B?
I hope that made that clear.. sorry...
A B
[] [] new cap
A B(f) C old cap
mburgess44 07-23-2010 07:55 PM
1 Attachment(s)
This might make more sense...
F cable is removed from the round cap and put on the oval cap -- any prong. Jumper goes from other prong on oval to old prong on round cap
beenthere 07-23-2010 08:19 PM
Close.
The "F" cable gets put to new cap.
Then a jumper is ran from the C terminal of the old cap. To the opposite terminal on the new cap.
mburgess44 07-23-2010 08:25 PM
Originally Posted by beenthere (Post 474269)
Close.
Okay,
F cable is taken off the old cap and put on the new.... got that
A jumper needs to go from the old cap C terminal to the new cap opposite terminal of where the F cable went.
Here is my question.... isn't a cable already on the C terminal of the old cap? if I connect a jump to the terminal where does the old cable I remove go to>?
beenthere 07-23-2010 08:42 PM
You don't remove any cable from the C terminal of the old cap. It should have an open spade left on it, for a jumper.
If it doesn't. then you run a wire from the contactor terminal that has the wire that runs to the old caps C terminal.
mburgess44 07-24-2010 03:42 PM
Thanks for your help. I added the new cap today but it still didn't work... I guess I'll call the HVAC guy...
The outside unit is just buzzing...
Marty S. 07-24-2010 04:10 PM
Look on the copper lines inside the AC for a small plastic cylinder with two wires coming from it. If it has a buttom on top push it. Fan went out would have tripped the high pressure switch, the cylinder, which needs to be reset.
mburgess44 07-24-2010 04:29 PM
Is it inside the same section where my cap is? If so, the only plastic piece I see if the one where my inside wires go in and the cap is connected to prongs... no button there..
beenthere 07-24-2010 04:36 PM
What brand and model number is your unit.
Marty S. 07-24-2010 04:50 PM
google "manual reset high pressure switch" for pictures
mburgess44 07-24-2010 05:31 PM
It's a Goodman 13 seer... I'll check on the model when the sun goes down. I've been stung by bee's twice today... ouch..
mburgess44 07-24-2010 05:49 PM
Goodman GSH13
mburgess44 07-26-2010 09:45 AM
I took the top off and can't seem to find it near the condenser either... is it possible that it doesn't have a high pressure switch?
