Help Me Please! Heating Question - HVAC - DIY Chatroom Home Improvement Forum
Old 12-07-2010, 09:56 PM   #1
Exclamation
Help Me please! Heating question
When i turn on my heat it only blows hot air for a short time then is blows room temp, Also the fan doesn't turn off. If i go outside and reset the breaker for the heat it will start working again for a bit then start blowing cool air again. What could be wrong?...
I have a Heil 5000, Model # CA5524VKD3, OUTSIDE
Thanks,
tmphuerta is offline   Reply With Quote
Old 12-07-2010, 10:28 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
you are resetting your control. i dont work on these (not used in this area). may have a control board with an led diagnostic. check in blower compartment or electrical compartment when system acts up b4 resetting power.........
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 12-08-2010, 11:57 AM   #3
Rewards Points: 516
Just in case you haven't, do a site search on Heil 5000. Similar cases are archived.
diyorpay is offline   Reply With Quote
Old 12-08-2010, 07:09 PM   #4
Clean the flame sensor with steel wool. This will fix your problem.
Heritage Mt. is offline   Reply With Quote
Tags
heat , heat loss , heil , hvac
In-Floor Heating Cable Trouble... sootybuttercup Electrical 24 12-18-2014 08:01 PM
Slate Floor Electric Underfloor Heating Lottie Flooring 6 03-19-2011 01:50 PM
Geothermal heating question Fisher HVAC 5 11-24-2010 05:23 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
kitchen floor/underfloor heating LanterDan Flooring 2 07-04-2006 07:17 PM
