Old 11-08-2010, 10:53 AM   #1
Help with LuxPro PSP722E Thermostat
I have a single stage heat pump with propane backup/aux heat.
1. Should I set the Luxpro 722 to be 1 stage or 2 stages of heat?
2. How do I control the point at which the Aux Propane comes on? The Swing setting looks like it MIGHT do this although it specifically says it controls multiple stages of heat/cool. Since my heatpump is single stage, I don't know if the AUX heat is considered a 2nd stage. Or is there another way to control how much temp variation there is in the room temp and the set point before the AUX comes on?
edfiero is offline   Reply With Quote
Old 11-10-2010, 07:49 PM   #2
Ouch!That'll leave a mark
Set your t-stat for 2 stage heat. your heat pump will be first stage and gas heat will be 2nd stage or Aux.
ridgevilleac is offline   Reply With Quote
Old 11-10-2010, 07:53 PM   #3
Professional
Does your stat have an emergency heat function? If not, then you don't have a stat that is compatible with your system
hvactech126 is offline   Reply With Quote
Old 11-10-2010, 10:21 PM   #4
An old Tradesmen
I don't think that thermostat is a dual fuel capable thermostat.
Old 11-18-2010, 10:22 AM   #5
Yes, the stat does have Emergency heat function. Yes, it is clearly compatible with my system.
ridgevilleac, thanks for the info. Do you have any idea on how to adjust when the 2nd stage comes on? Is this the 'swing' settings, or is there another way to control this? I am expecting there to be the ability to set the stat so if the set point is more than 'x' degrees from the room temperature, then turn on the AUX heat. OR... if the 1st stage runs for more than 'x' minutes and does not reach the setpoint, then turn on the AUX heat.
Old 11-18-2010, 06:17 PM   #6
An old Tradesmen
Does it say dual fuel compatible in the instructions anywhere.
Old 12-06-2010, 03:49 PM   #7
Manual says UNIVERSAL compatibility. Works with all systems, Heat Pump, Oil, Gas, etc.
Old 12-06-2010, 05:50 PM   #8
An old Tradesmen
Ok. So then in the manual. You see a section that tells you how to set up the lock out temp for the furnace. Right. And it doesn't run the heat pump and furnace at the same time right.
Old 12-06-2010, 06:32 PM   #9
Professional
gotta love the Hdepot and their stats and willingness to sell you anything even if they have no idea what they are talking about.
IT IS WHAT IT IS
Old 12-06-2010, 07:31 PM   #10
If you have just a standard hp stat a outdoor stat and lock out relay are required I would recommend a pro to install. Honeywell makes a stat called prestige comes with a outdoor sensor. Very easy
To install. Odu and furnace cannot at the same time will cause compressor failure
Hixheat1 is offline   Reply With Quote
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 06:40 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-10-2010 12:58 AM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 08:48 PM
Replacing thermostat...................... sktn77a HVAC 6 09-02-2009 11:07 PM
Need Help with Luxpro 722E Thermostat tedzia HVAC 1 07-23-2008 06:18 PM
