Help For A Locked Screen On A Honeywell TH8320 Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 06-14-2009, 08:38 PM   #1
Help for a locked screen on a Honeywell TH8320 thermostat
My new Honeywell thermostat shows screen locked at all times. It was just installed Friday. After coming home from the weekend it is so hot and the screen display says "screen locked" the whole time. I have removed the face plate and taken out batteries and reinstalled. Now what? Please help
TanyaMendenhall is offline   Reply With Quote
Old 06-14-2009, 09:45 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Here is a link for the stat.
Go to the section Advanced Settings and this should walk you through unlocking the screen
http://www51.honeywell.com/pacific/c...ionPRO_Use.pdf
Old 06-14-2009, 10:22 PM   #3
Home Air Direct's Avatar
This is from the 8320U/8321U manual that I have.
Good Luck
Keypad
Lockout
Installer Setup #0670
0 = Unlocked
1 = Partially Locked
2 = Fully locked
Unlocked: all functions are available.
Partially locked:only temperature up and down keys and
ability to enter and modify Installer Setup mode are available.
Fully locked: only ability to enter and modify Installer
Settle down! If you were that important, the city would give you lights and a siren for your car
Home Air Direct is offline   Reply With Quote
Old 06-15-2009, 11:05 PM   #4
An old Tradesmen
Rewards Points: 6,088
Guess your hubby didn't want you to adjust the settings.
new honeywell rth6300b to replace very old honeywell thermostat Designman20 HVAC 2 05-06-2009 05:43 AM
Honeywell VisionPro Thermostat infoskr HVAC 32 12-17-2008 04:44 AM
Wiring/Programming of a Honeywell TH8320 Thermostat homrjheath HVAC 4 10-15-2008 02:30 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 08:40 AM
