Old 12-06-2009, 10:18 AM   #1
Help with lennox furnace will not stay on.
I have a Lennox G24M2-60A-10 and it will not stay on. It comes on for a few minutes then shuts off. The blinking light code suggests "prim. limit open" which from reading forums could be a dirty filter. So I replaced the filter with a new one and same problem. But I ran the furnace without the filter just to see what would happen and it ran fine. I know running it without a filter is bad so how do I fix the problem? Any thoughts and advice would be greatly appreciated. Thanks slowhand
slowhand is offline   Reply With Quote
Old 12-06-2009, 10:53 AM   #2
Hvac Pro
Make sure all your vents/registers/dampers are open. Check the underside of the A/C coil for dirt buildup if you have one.
Old 12-06-2009, 10:59 AM   #3
Hey thanks for responding Yuri. I checked the air vents and there open but not sure what or where the A/C coil is.
Old 12-06-2009, 08:40 PM   #4
Houston204's Avatar
The evaporator coil is usually above the furnace in a vertical application,
It is much easier to access and clean in a horizontal application.
Houston204 is offline   Reply With Quote
Old 12-06-2009, 09:10 PM   #5
hvac tech
Have you ever left the filer out of the furnace for a period of time during the heating or cooling season. What brand of filter did you install.
marchvac is offline   Reply With Quote
Lennox Furnace G27M Series – Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Lennox Furnace burner won't stay on stevea7777 HVAC 43 01-07-2013 03:17 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
