-   -   Help with lennox furnace will not stay on. (http://www.diychatroom.com/f17/help-lennox-furnace-will-not-stay-58620/)
slowhand 12-06-2009 09:18 AM
I have a Lennox G24M2-60A-10 and it will not stay on. It comes on for a few minutes then shuts off. The blinking light code suggests "prim. limit open" which from reading forums could be a dirty filter. So I replaced the filter with a new one and same problem. But I ran the furnace without the filter just to see what would happen and it ran fine. I know running it without a filter is bad so how do I fix the problem? Any thoughts and advice would be greatly appreciated. Thanks slowhand
yuri 12-06-2009 09:53 AM
Make sure all your vents/registers/dampers are open. Check the underside of the A/C coil for dirt buildup if you have one.
slowhand 12-06-2009 09:59 AM
Hey thanks for responding Yuri. I checked the air vents and there open but not sure what or where the A/C coil is. :(
Houston204 12-06-2009 07:40 PM
The evaporator coil is usually above the furnace in a vertical application,
It is much easier to access and clean in a horizontal application.
http://i151.photobucket.com/albums/s...ilcleaning.jpg
http://i151.photobucket.com/albums/s.../evapcased.jpg
http://i151.photobucket.com/albums/s...acediagram.jpg
marchvac 12-06-2009 08:10 PM
Have you ever left the filer out of the furnace for a period of time during the heating or cooling season. What brand of filter did you install.
