Old 08-08-2008, 08:39 PM   #1
Default Help! Just changed my Fan Controler (ICM 275) now system "false starts" when cooling
A/C Question: Just replaced Fan Control Unit and now the Blower false starts every time the Cooling goes on
I had an HH84AA009 in my carrier air handler. This air handler does both cooling and heating. A few days ago, the blower stopped turning off and remained constantly in the "on" position (even after moving the switches on the thermostat to "off" and Auto)
When I'd power off my system and open the unit, If I tapped the relay with a screw driver the fan would turnitself off, however once it went on again it wouldn't turn off.
I replaced the unit with a new ICM275. I replaced wire for wire one at a time, so I am pretty sure that I did it correctly.
Now, the fan works well, however when you put the unit into cooling mode, the blower will go on, and then as soon as the cooling kicks in, the unit kind of "resets" the blower turns off and then tries many consecutive "false starts"
Have I done anything wrong?
Is this newer controler board (with new kind of relays) different and therefore I need to change the wire connections
The new replacement board is different than the original one. The old one has the big old style relays while the new one has the newer relays. This new Board (ICM275) is the currently availible replacement for many legacy Carrier boards including the HH84AA009 (which is the one I had). The board has the same form factor and all of the connection terminals are labeled exactly the same as in the old board. As mentioned before, I connected the wires from the old to the new one at a time to make sure I got them right.....
There is a delay feature that can be adjusted by moving a potentiometer dial.
Maybe somewhere out there knows if these newer boards (that use SPST-NO blower relay, SPDT blower speed relay and SPST-NO relay for humidifier) require any wiring changes from the old boards (that use SPST-NC or DPST-NC heating fan relay and DPDT cooling fan relay 2f)
THe board is made by ICM controls and the schematics are on the icm site.
UPDATE!, it seems that when I set the blower settings at the stat to "on" instead of "auto" both the cooling and blower work. When I change the setting to auto, I get the problems.
this is a link to what the old board looks like:
this is a link to how the new one is wired:
Last edited by redmachodevil; 08-10-2008 at 06:26 PM. Reason: UPDATE / Clarification and pics
redmachodevil is offline   Reply With Quote
Old 11-04-2009, 06:40 PM   #2
Default Icm275
i am about to purchase and replace my HH84aa009 with the ICM 275..what did you find out about the blower motor glitch on cooling
papasru is offline   Reply With Quote
Old 11-04-2009, 07:32 PM   #3
as seen on tv
Try disconnecting low voltage wiring. Jump out r to g see if it still does it, If it does not, inspect wiring for nicked conductors in the low voltage wire
qbert is offline   Reply With Quote
Old 11-04-2009, 07:57 PM   #4
Does the new board have a Carrier part # on it? If not I would contact Carrier and be sure it is an exact replacement board. The chips on those boards tell the unit how to operate. Manufacturers often have different contractors program their boards to operate the unit the way they want. May not be what your problem is,but I would check to be sure.
mikef54 is offline   Reply With Quote
More On This Topic
How to Install a Fan Relay
How to Install a Fan Relay by Expert Village
Hi I'm Doug. I work with twenty great guys in St. Louis at Doug Jenkins Custom Hot Rods, and we're going to do some work for you today on Expert Village. Now we're going to tame an octupus. We need to put in a fan relay. And we're just going to choose a... Read More »
In this clip we're going to talk about the proper way to remove and replace an electronic cooling fan. In this step we're going to go over the proper service procedure for removal of the actual cooling fan assembly. And we're going to go over the test... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solution. On behalf of Expert Village, we are going to be doing a blower door test on this home. What is the benefit of me knowing how air tight my home is. And again, throughout all of this process... Read More »
In this segment, we're going to cover safety and various issues involved in replacing a radiator. In the automotive radiator, the basic coolant that is used is antifreeze. That's what it is referred to and its main chemical is an ethanol glycols. This is... Read More »
In this clip we're going to talk about the proper way to remove and replace an electronic cooling fan. In this step we're going to talk about the tools required in order to remove and replace your electronic cooling fan. What I have here in front of me... Read More »
new heating cooling system agrace HVAC 4 07-25-2008 09:26 AM
New House, new system, poor cooling Faulknertw HVAC 15 07-09-2008 12:06 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 09:32 AM
Problems with Central Air Cooling System golfgod04 HVAC 4 05-27-2007 10:51 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
