Help Its Cold - HVAC - DIY Chatroom Home Improvement Forum
Old 12-06-2010, 08:07 PM   #1
help its cold
im having issues hooking up my new digital therm i currently had a slide mecruy one
the wire colors are black yellow tan orange blue green red white
the new therm is as follows
c,b,o,w,w2,y,y2,rh,rc,g,a
please help its cold
shownuff is offline   Reply With Quote
Old 12-06-2010, 08:08 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
see what terminals those colors are hooked to on furnace
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 12-06-2010, 08:10 PM   #3
i cant problem is it was taken apart before i got to it
Old 12-06-2010, 08:11 PM   #4
AKA HVACTECHFW
you cant see what wires are hooked up in your furnace by going to your furnace or air handler and removing the door and looking?
IT IS WHAT IT IS
Old 12-06-2010, 08:12 PM   #5
its for the thermostat it had a old mercury switch type on it its actually a friend of mine who took his off trying to convert to a digital
Old 12-06-2010, 08:13 PM   #6
and he didnt label his wires so i was going off mine since i switched to digital but mine lists the black going to e and he doesnt have an e terminal
Old 12-06-2010, 08:14 PM   #7
Do you have a heat pump b is used if you have rheem or rude if not disregard b and y2 the rest should wire the same. Y 2 is used if you have a two stage odu. Another answer
Hixheat1 is offline   Reply With Quote
Old 12-06-2010, 08:15 PM   #8
AKA HVACTECHFW
ok, your thermostat wires hook on the other end of them to the furnace! Your thermostat controls the furnace. there for if you check to see what the wires hook to there, it will help you determine what terminal to hook them to at the thermostat
IT IS WHAT IT IS
Old 12-06-2010, 08:16 PM   #9
E is the same as w 2
Old 12-06-2010, 08:17 PM   #10
AKA HVACTECHFW
read the instructions?
IT IS WHAT IT IS
Old 12-06-2010, 08:17 PM   #11
yes it is heat pump with emergency heat the problem i had is i dont know where the black and tan wires go
Old 12-06-2010, 08:19 PM   #12
what about white wire
the way mine is wired is
black is e white is aux yellow is y , g is green ,o is orange red is r and c is blue
Old 12-06-2010, 08:20 PM   #13
Experienced
Jackofall1's Avatar
How about this
http://www.google.com/images?rlz=1T4...w=1419&bih=639
Old 12-06-2010, 08:20 PM   #14
What do you have hooked up you may not need the black and tan they be extra
Old 12-06-2010, 08:21 PM   #15
You should go to the furnace and see if they are used
Hot Water Turning Cold - Could it be the washer/dryer? kissiffer4 Plumbing 3 01-28-2010 05:47 PM
Cold air return questions ekulrenlig HVAC 19 10-09-2009 02:44 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 11:29 AM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 09:05 AM
