Help With Installing Trane TZEMT400AB32MAA Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 12-24-2011, 03:23 PM   #1
Help with installing Trane TZEMT400AB32MAA Thermostat
Happy Holidays everyone!
I'm trying to install a new thermostat and am totally confused on the wiring from old to new. Can anyone offer any advise? Do I need to run a wire from RC to RH and stick the red wire coming out of the wall into either?
OLD:
NEW:
Not sure what to do with the Red wire.
Thanks in advance!!
alohadustin is offline   Reply With Quote
Old 12-24-2011, 04:23 PM   #2
An old Tradesmen
Rewards Points: 8,194
It goes in either the RC or RH, and RH and RC need to be jumpered together.
Old 12-24-2011, 04:44 PM   #3
Houston204's Avatar
Rewards Points: 556
http://www.trane.com/residential/dow...structions.pdf
Your manual shows heat pump wiring. No jumper between Y and W is required with this model (you probably already knew this).
Houston204 is offline   Reply With Quote
Installing new thermostat / wiring question roliemu HVAC 3 12-03-2011 07:48 AM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 04:32 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
Installing a thermostat machx7 HVAC 7 06-01-2010 01:37 AM
Installing new thermostat, getting no response fupafupa HVAC 3 05-25-2010 02:01 PM
