Old 07-24-2011, 08:38 PM   #1
Help installing Honeywell
I have a Carrier 2 stage with humidity control Heat pump,the thermostat is TSTATCCPRH01-B thermostat which has the following is wired.
0/w2 - Orange wire
y1/w2 - Black wire
R - Red wire
G - Green wire
y/y2 - Yellow wire
w/w1 - White wire
Humid stat
C - Blue wire
dhum - Brown wire
S1 - green wire
S2 - brown wire
The honeywell is the Prestige Hd Thermostat Kit Ythx9321r5012
How do I wire for the for the Honey well .
The manual has the following
3h/2c Heat pump.
c - common
R
Rc
O/B change over valve
aux auxiliary Heat
y compressor contractor stage 1
y2 compressor stage 2
g fan relay
L Relay
any special setting that need to be set up in the stat
Thanks for your help.
Smallville is offline   Reply With Quote
Question on installing an Honeywell RTH6350 programmable thermostat. outdoorted HVAC 3 01-02-2011 07:48 PM
Honeywell TrueSteam wont work! Stewart Daniel General Discussion 18 12-20-2010 08:41 AM
Help Installing Honeywell Thermostat.... jobondur HVAC 14 03-30-2010 11:01 PM
Installing a Honeywell 5-1-1 'RTH2410??? Skybeatle HVAC 4 03-28-2010 12:31 AM
Replacing Honeywell thermostat with another Honeywell flipz HVAC 4 02-06-2010 05:19 PM
