Help Im Cold - HVAC - DIY Chatroom Home Improvement Forum
Old 11-22-2010, 09:56 PM   #1
Help im cold
A pipe leakend in my basement and since then my furnace has not worked. I had someone look at it. The curcuit board and flame sensor was replaced and it still will not kick on. The person i have attempting to fix it is not a true furnace repair specialist and just keeps trying things. Any idea what else it could be?
MELCAT51 is offline   Reply With Quote
Old 11-23-2010, 04:24 AM   #2
An old Tradesmen
Rewards Points: 7,814
While a real HVAC company probably would charge you more for the "real" repair. They would probably have been cheaper in the short and long run.
Without a better description of what the furnace does or doesn't do. Can't offer much help.
Were any voltage checks done?
Old 11-23-2010, 05:50 AM   #3
firestarter
yes he is right . i tryed that this year to save some cash and for two hundred dollars he made it worse.i had to call a pro and now it works great . i have learned you get what you pay for.
firestarter is offline   Reply With Quote
Hot Water Turning Cold - Could it be the washer/dryer? kissiffer4 Plumbing 3 01-28-2010 04:47 PM
Cold air return questions ekulrenlig HVAC 19 10-09-2009 01:44 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 10:29 AM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 08:05 AM
