Help - I Need My Humidifier Working When Blower Is On, Not Just Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 12-19-2009, 10:20 PM   #1
Help - I need my humidifier working when blower is on, not just heat
Hi all,
I'm having a major humidity problem in my house; relative humidity is between 25-28% (not good for my 9 month old daughter or my woodwork), so I need to increase it.
I have a Lennox G61MPV furnace, a General Aire 1042 humidifer, and a Lennox ComfortSense 7000 thermostat. The solenoid on the humidifier is wired to a transformer which is connected to the HUM terminals on the furnace board. My problem is that the solenoid only seems to be pumping water through the humidifier when the furnace is heating; if I put the fan on independently (it's a DC motor and operates at 35% when circulating) the humidifier doesn't kick on.
Is there any way I can tell the thermostat to tell the furnace to put the humidifier on when the blower is on, rather than the heating stage only? Or to change the furnace board so that it provides power to those terminals when the blower is on?
I really need to get this solved!
canuck88 is offline   Reply With Quote
Old 12-19-2009, 10:25 PM   #2
An old Tradesmen
Rewards Points: 6,892
Should be able to connect the transformer to the EAC terminal. its energized when ever the fan runs.
You'll also need to hook your humidifiers water line to the hot water pipe. or you won't get much humidification by just running the fan.
There is a good chance. That by just connecting the humidifier to the how water pipe that it will increase your humidity.
Old 12-19-2009, 11:19 PM   #3
Great suggestion - I actually just got up from the basement from doing exactly that! Works great. Now I just need to re-route the water supply to the hot water heater (which sucks because the current set-up is really well done and i don't want to mess with it
Thanks for the help!
Old 12-20-2009, 07:09 AM   #4
Rewards Points: 292
If your hot water line is near (next to) your cold water line, you could turn off the saddle valve (cold) and install one on the hot line.
Might have to add some tubing and connectors.
delta
veesubotee is offline   Reply With Quote
Old 12-20-2009, 10:25 AM   #5
Yep hook to hot water and EAC terminal. You can also get rid of that extra tranformer and run the humidifier from the H and C terminals in the thermostat. Change the installer humidify configuration to precision after rewiring. It will bring on the heat for a humidity call ( up to 2 degrees over the temp setting).
Old 12-20-2009, 10:29 AM   #6
An old Tradesmen
Doesn't that kind of defeat the comfort ability of the furnace then. At milder outdoor temps.
With proper humidity, you generally don't need the temp as warm to feel warm.
Old 12-20-2009, 10:38 AM   #7
I agree but that is the function of that setting, to get the humidity to a comfor level quick as possible. Same with the dehumidify setting in the summer will run AC 2 degrees cooler untill humidty levels are what you want. Once the humidity reaches the called for levels then the thermostat uses temp like normal.
Old 12-20-2009, 10:45 AM   #8
An old Tradesmen
I'm a fan of the IAQ stat for slowing the blower and running the A/C to dehumidify(up to 3 over cool).
But, usually remind those customers that if they tighten up their home. It should never have to over cool to dehumidify.
Same thing will hold true to humidify.
Old 12-20-2009, 10:47 AM   #9
Hvac Pro
yuri's Avatar
Rewards Points: 1,834
Use a copper water line to the humidifier if using hot water. Plastic is not rated for hot water. With a flo thru you are wasting hot water. I use cold all the time and have never had a problem. Check if you have a fresh air pipe from outside to the return duct of the furnace. I set the damper for 1/2 open in the winter or it brings in too much dry air.
Old 12-20-2009, 03:24 PM   #10
JohnH1's Avatar
Dont forget you will need to turn off the humidifier in the summer or it will run with the A/C using the EAC power.
JohnH1 is offline   Reply With Quote
Old 12-20-2009, 05:04 PM   #11
You can also use a sail switch.
http://electronicaircleaners.com/ima...007_photo1.jpg
Old 01-01-2010, 08:55 PM   #12
Hey guys, just wanted to join up and say thank you so much for the EAC connection tip. We had an Aprilaire blowthrough installed several years ago and it's never been able to keep up. This will help a lot!
Next I'll move the water tap to the hot water line, but since the missus likes the water heater set to "super scald" I need to run a pvc drain line first so I don't have a melted tube mess.
Blorton is offline   Reply With Quote
Old 01-01-2010, 10:10 PM   #13
Hvac Pro
yuri's Avatar
Use a copper water line for the SUPPLY to the humidifier as the plastic line is not rated for hot water. The drain is not so important.
Old 01-02-2010, 12:05 AM   #14
Thanks Yuri.
The feed line already in place is a copper with plenty of slack to move to the hot line, but there is a black plastic line after the water servo that I will have to look at.
Old 01-02-2010, 03:26 AM   #15
The eac is 110v and the OPs humidifier is 24 v. He'll still need the the humidifier transformer.
hvaclover is offline   Reply With Quote
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 06:15 AM
No heat but working AC xevier69 HVAC 4 01-30-2009 05:31 PM
Trane xv80 furnace blower not working jim2138 HVAC 2 03-22-2008 04:55 PM
baseboard heat upstairs not working TraceyLee HVAC 1 10-23-2005 05:47 PM
