Help With Hydronic Heat. - HVAC - DIY Chatroom Home Improvement Forum
Old 09-22-2013, 10:33 PM   #1
Help with Hydronic heat.
I have an addition that we have been heating with a propane wall heater but would like to just run a baseboard or two into the addition. So my question is can i just tee off of an exisiting zone (not on the furnace itself but on the piping near where I want them) or do I have to add another feed and return pipe
bobbop is offline   Reply With Quote
Old 09-22-2013, 10:35 PM   #2
Hydronic**
Old 09-23-2013, 05:33 AM   #3
An old Tradesmen
Rewards Points: 6,130
Additions are best served by their own zone.
Old 09-23-2013, 08:11 AM   #4
Ok how dificult/expensive is that
Old 09-23-2013, 11:32 AM   #5
Never mind there is an unused cast iron radiator on the basement I'm just going to cap the return line. Shark bite elbow the feed line, tee the return line closer to the adition and then use pex to go to the addition to hook up the radiator. I was told that you could use pex for this type of application which is good because my local home improvement store has the oxygen barrier stuff for 48 cents a foot.
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 04:59 AM
Relief valve on hydronic heat leak after power failue fod01 HVAC 3 11-05-2012 01:00 PM
hydronic zones get some heat when not called 1619Farm Plumbing 7 12-22-2010 10:28 AM
Using Gas heat during Defrost mgroves HVAC 15 12-18-2010 06:51 PM
Bamboo over Hydronic Radiant Heat SusieQ2010 Flooring 0 06-16-2010 04:47 PM
