Help - High Static Pressure & Keep Getting Possible Foil Coil Error - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 09-11-2012, 01:17 AM   #31
Thanks, I'll try to give that a go and hopefully it all work out
kolo is offline   Reply With Quote
Old 09-11-2012, 09:11 AM   #32
Rewards Points: 314
First off, these guys all know their stuff!!!!!!
to really do this the right way, you need to invest some time (and pocket change) and do a manual J calculation. This will tell you what you need as far as air flow to each room. With that in hand, you then should do a manual D to find the correct size duct and register for each room.
Just my two cents worth and again the ideas presented here so far are great!!!!
bobinphx is offline   Reply With Quote
Old 09-11-2012, 03:57 PM   #33
An old Tradesmen
Rewards Points: 7,816
Your right, a room by room Manual J and a manual D would be good. Unfortunately, the manual D won't help much since he doesn't want to open his walls to change out those 5" supplies.
Old 09-13-2012, 11:32 AM   #34
I can only get 18 inch Wide for the supply truck, should I change the 15" to an 18" and change the 10" to 12" or 14"
Old 09-13-2012, 03:57 PM   #35
An old Tradesmen
If thats all the bigger you can get, then get the 18", and change the 10 to a 14.
Old 09-13-2012, 08:27 PM   #36
I'll be doing most of the work by myslef any tips or suggestions. I put over 6000.00 already into it and afford to put more in.
Old 09-13-2012, 08:36 PM   #37
An old Tradesmen
You'll need good sharp tin snips/aviation snips. Take your time, don't rush it. Sheet metal cuts hurt, the zinc burns in a cut.
May have to drop the boots of the supplies to put the new duct up. Its hard to put a trunk line up and connect the supply runs to it as you hang it. So its easier to drop the register boot, hang the duct, and then put the supply run back up.
If you can get vanes, you might want to use tghem to aid the air in turning to the 14X8 duct. Greatly increases air flow.
Old 09-13-2012, 11:45 PM   #38
Thank you beenthere you been great help
Old 09-16-2012, 09:27 PM   #39
I was wondering should I only change 5in to 6in in the areas that aren't getting properly flow. Also I have about the 7 outdoor vents in the crawling space that lets air flow through can I close them up. My crawling space is all cement, it gets pretty cold during winter.
Old 09-16-2012, 10:29 PM   #40
Rewards Points: 610
because.... The main trunk line is already carrying maximum volume/static pressure, which will drop slightly further down the line, due to resistance losses in the duct then, ..this allows more input to help total air flow..sort of like by passing a traffic jam and getting back onto the main road where the traffic isn't so heavy.
NOTE..oops...came in at wrong time and place for this comment( missed a page) but, I'm sure you get the point..
techpappy is offline   Reply With Quote
Old 09-17-2012, 05:37 AM   #41
An old Tradesmen
Changing them to 6" won't hurt. how much it will help varies on how long of a section is replaced.
Most crawlspaces can be closed up. This helps with both heating and ooling the house, since probably lose to 60% of your infiltration is coming from your crawlspace, if it hasn't been sealed from the house. Some will need a dehumidifier.
Old 09-19-2012, 01:16 PM   #42
there's also two registers in the crawling space two
Old 09-24-2012, 05:25 PM   #43
An old Tradesmen
Then the crawlspace better be sealed.
Slantfin Galaxy Boiler Pressure Mystery chiefswabjockey HVAC 18 11-15-2011 05:37 PM
LP gas high pressure line ChrisDIY Plumbing 6 10-21-2011 10:59 AM
Static Pressure befor filter or after key1cc HVAC 33 11-23-2008 09:56 PM
High pressure bjr23 Plumbing 1 03-27-2007 07:24 PM
High pressure in water line atlfiveo Plumbing 5 02-06-2007 09:04 PM
