Help - High Static Pressure & Keep Getting Possible Foil Coil Error - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-09-2012, 07:05 PM   #16
An old Tradesmen
Rewards Points: 6,464
Because 3/4 of the way down, your trunk line has lost most of its pressure/air. The helper gets the needed air to the last 25%$ of the duct/runs.
Old 09-09-2012, 08:13 PM   #17
So I would leave everything the way it is (I mean all the duct going to the registers) and just attach the helper 3/4 of the way
kolo is offline   Reply With Quote
Old 09-09-2012, 08:23 PM   #18
An old Tradesmen
Yes. that will get you better air flow to the end registers. And lowe your static some.
Old 09-09-2012, 08:45 PM   #19
Thank you Beenthere, You've been great help and this site is also great with a lot of people with knowledge. I'll give it a go and see if that fixes the problem
Old 09-10-2012, 03:42 AM   #20
Hey Beenthere, I made a little diagram showing my duct work. I little confused now maybe you or someone can help me with this.
Help - High Static Pressure & Keep getting Possible foil coil error-ductwork.jpg
Old 09-10-2012, 05:17 AM   #21
An old Tradesmen
Which individual duct has the rooms that don't get much air.
Old 09-10-2012, 02:48 PM   #22
Its the 10in X 29 which goes to my living room/dinning and it has 10 ceiling.
Old 09-10-2012, 08:14 PM   #23
An old Tradesmen
The 15" that feeds it, is it a 15X7, or 15X8?
Old 09-10-2012, 08:24 PM   #24
its 15 X 8
Old 09-10-2012, 08:33 PM   #25
An old Tradesmen
Barely able to carry 850 CFM. They set it up so that the 15X8 is trying to move enough air for an 18X8. When you include the air the 8X8 duct moves. Almost need to get rid of the 15X8 and much larger duct. It would have to be bigger then18X8 so that it can also carry the air that used by the 5" supplies already taken off of the 15X8 before the 10X8 and 8X8 duct.
While a helper duct would work. Its almost as much work as just running a larger trunk line.
Old 09-10-2012, 09:48 PM   #26
So I should replace what I highlighted in Red with 18 X 18 or bigger to balance things out more
Old 09-10-2012, 10:18 PM   #27
Sorry I forgot to attach the image
Help - High Static Pressure & Keep getting Possible foil coil error-ductwork_replace.jpg
Old 09-10-2012, 11:06 PM   #28
An old Tradesmen
Not knowing how many supplies are tapped from it, I would guess 24X 8 for it. And then increase the 10x8 to 14X8.
Old 09-10-2012, 11:20 PM   #29
There are 7 Registers on the 15th and 8 registers on the 10th one
Old 09-10-2012, 11:25 PM   #30
An old Tradesmen
24X8. And increase the 10 to 14X8
The Following User Says Thank You to beenthere For This Useful Post:
kolo (09-11-2012)
Slantfin Galaxy Boiler Pressure Mystery chiefswabjockey HVAC 18 11-15-2011 06:37 PM
LP gas high pressure line ChrisDIY Plumbing 6 10-21-2011 11:59 AM
Static Pressure befor filter or after key1cc HVAC 33 11-23-2008 10:56 PM
High pressure bjr23 Plumbing 1 03-27-2007 08:24 PM
High pressure in water line atlfiveo Plumbing 5 02-06-2007 10:04 PM
