-   -   Help with heating: diverter tee system (http://www.diychatroom.com/f17/help-heating-diverter-tee-system-5824/)
smw 01-09-2007 07:13 PM
I have a house built in 1950 that uses a hydronic single pipe diverter tee system. The system is plumbed with iron and steel and has started rusting and leaking. My wife and I have decided to replace it with copper.
Questions:
The original system was hung from the joists in the basement using pipe strapping. It's about 3-4" down. In the new system I'd like to notch the joists and mount the pipe directly (loosely, of course, to allow for expansion) to them, since I'm finishing the basement and would prefer to hide the pipes. Any caveats with this?
Also, we need to add an additional room to the system, but it uses baseboard radiators, not the in-wall type that the rest of the house has. From an article I read (http://www.heatinghelp.com/heating_howcome3.cfm), it appears that this should be installed at the end of the line. Any comments?
Your suggestions are welcomed.
Thanks,
Steve
redline 01-09-2007 08:45 PM
Not wise to notch the joists.
How long is the span of the joists?
What is the thickness and height of the joists?
smw 01-09-2007 09:42 PM
Span is about 12 feet, joists are a nonstandard size of 2.5x7 (I had been calling them 3x8s until I actually measured them)...
Keep in mind, I was only planning on notching them about a half inch or so...
trollmastergeneral 01-10-2007 06:05 AM
When you say one pipe hydronic that perks my ears.When you have only one pipe that leads me to believe you have a stem boiler which you may not want to move the pipes if you like having heat.could you clarify what you mean by one pipe
smw 01-10-2007 08:15 AM
It's a standard one pipe hot water system (see the page I linked to in my first post). They were very popular up through the 1950s.
bradley_d15 02-13-2008 10:50 AM
SMW, How did you make out? I have the same system that I wish to upgrade to either coppper or PEX. Feel free to email me with any information!!
