Old 12-02-2009, 02:18 AM   #1
Help with heat pump!!
Okay, we bought a home a couple of years ago with a central air unit (do not know if it has a heat pump or not). The previous owners used it as a summer house and probably did not need heat. Here's what we have and what happens.
A/C works good
We have to use $Emergency Heat$ in the winter. When I turn on the regular heat switch the fan blows but it is cold air. It does not feel like the a/c but rather just air that is the temp of the air outside. Inside the thermostat the O wire is not hooked up but is present. Outside I cannot remmber what is hooked up with what because I am writing this at 2 in the morn and I may check this tomorrow if the rain holds off.
So what I need to know is do I have a heat pump or how can I tell?
mike85rob is offline   Reply With Quote
Old 12-02-2009, 02:21 AM   #2
a note on my above post. Do not assume that whoever hooked the system knew what they were doing. I am not very experienced in hvac but I am with elecrical and lets just say that when we bought the place I had to do a lot with the electric to bring it up to code.
Old 12-02-2009, 09:45 AM   #3
Get the model number of the unit and then look it up on the manufacturer's website or post it here.
Or pull the cover and look for the presense of a reversing valve. Do this with the breakers off to be safe.
hennyh is offline   Reply With Quote
Water Source Heat Pump installation JLMitchell HVAC 6 11-30-2009 04:23 AM
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 04:05 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 08:37 AM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 03:11 PM
