Help! Hazardous Chimney! Is B-vent Sufficient For Roof Venting? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-08-2011, 06:52 PM   #1
Help! Hazardous chimney! is b-vent sufficient for roof venting?
Hello,
I'm new on this forum and I seek some help for my brick chimney that is kinda damaged (see the pics below), to say the least.
https://picasaweb.google.com/1117996...47132068738930
https://picasaweb.google.com/1117996...47133692262722
My immediate concern is that the chimney falls down and injures someone
There is a non-functional brick/mortar structure above the roof line and in the attic. Inside this structure, there is a b-vent that is coming from the 2 gas space heaters all the way above the roof line.
My idea is to remove the bricks and leave the b-vent outside the roof only by installing plywood and shingle in place of the larger hole and install a collar and new flashing around the b-vent above roof line.
Does someone know if it's the right way to proceed and give me some suggestions? Is there something I'm missing?
Thanks for helping if you know about that!
Timcanada is offline   Reply With Quote
Old 10-08-2011, 07:43 PM   #2
Yikes, your chimney is in rough shape! Looks like you're going about it in the right way. Just be sure to observe all clearances from combustibles, eg. don't put the plywood or shingles right up against the b-vent, leave at least an inch. Also, your vent must extend a minimum distance above your roof, depending on the pitch.
hvac benny is offline   Reply With Quote
Old 10-08-2011, 08:31 PM   #3
Thanks for your help, hvac benny!
I need to do a bit of homework on the clearance then to make sure I get it right. I'm going to read the Ontario building code.
For the distance, I know it must be 2' over the ridge of the roof: I have to double-check if it's currently the case.
Old 10-09-2011, 12:46 AM   #4
I didn't notice that you're from Canada also, I'm in Vancouver. You are correct about the two feet; that info can be found in the Natural Gas and Propane Installation Code (B149.1). I'd also check whatever regulations Ontario uses that may supersede the B149.1. I don't think you'll have any that do, but you never know with all the snow you poor bastards get .
Tags
b-vent , brick chimney , natural gas , roof venting , venting
venting radiator boiler through bigger vent amakarevic HVAC 9 09-21-2011 11:43 AM
vent free insert with dismantled chimney? carolynaudet Building & Construction 0 08-28-2011 06:19 PM
electrick wire next to vent or brick chimney? ptcamaro Electrical 2 04-01-2008 11:28 PM
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 12:23 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 10:57 AM
