Help Getting Furnace To Run In Fan Mode? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-09-2012, 07:31 PM   #1
Help getting furnace to run in fan mode?
Hi,
I have a gas Trane XE90 gas furnace with a Honeywell RTH2510 thermostat. The furnace work great in the heat mode, but I would like to run the blower during hot weather to circulate the cooler air in the basement. When I switch the thermostat to cool and run it doesn't come on. According to the wiring diagram I have it wired right. There are only two wires a red and white.
Any help is appreciated,
Bob
unioncreek is offline   Reply With Quote
Old 07-09-2012, 08:05 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
you need a third wire on G at both furnace and t-stat.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 07-09-2012, 08:54 PM   #3
I was thinking that I might, but when the old thermostat was on there you switch it to fan and it would run.
Bob
Old 07-09-2012, 08:56 PM   #4
AKA HVACTECHFW
need 3 wires.. no way around it. other than a high end stat with a module or to use an add a wire kit.
IT IS WHAT IT IS
Propane Furnace - Diminishing Gas Supply After Ignition edro HVAC 9 01-13-2012 04:24 PM
Furnace running proper? Spydey HVAC 6 12-16-2011 07:57 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Help Needed ... turn on circulation pump when furnace in AC mode? Diranged HVAC 12 06-04-2009 06:33 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
