HELP! Furnace Not Working After Thermostat Change... - HVAC - DIY Chatroom Home Improvement Forum
Old 03-11-2013, 08:53 AM   #1
DIYer
Rewards Points: 249
HELP! Furnace not working after thermostat change...
Hey guys.
I have a natural gas furnace and I temporarily disconnected my thermostat since I am repainting my hallway.
I reconnected the same thermostat the exact same way and it will not turn on anymore. I was planning on replacing it but for now I figured I would reconnect the same one just to make the furnace work.
The thermostat does not go on any more.
I am sure the wires are hooked up to the correct places, I even made a diagram before disconnecting it.
What am I doing wrong? My breaker that powers the furnace did not trip and I flipped it off and back on again just incase.
Any help would be greatly appreciated.
Thanks.
VitoB is offline   Reply With Quote
Old 03-11-2013, 09:12 AM   #2
Roofmaster
Rewards Points: 2,210
Did you Flip it off before you disconnected anything, Or did you flip the breaker on and off after you reconnected it?
Does it take batteries?
What make and model is it?
Old 03-11-2013, 09:48 AM   #3
DIYer
Rewards Points: 249
No I didn't flip the breaker off, big mistake.
I am assuming I may have shorted something?
Old 03-11-2013, 10:12 AM   #4
HvacWiz's Avatar
Rewards Points: 252
Check for a blown low voltage fuse on furnace circuit board
HvacWiz is offline   Reply With Quote
Furnace not working mwpiper HVAC 15 04-21-2012 05:57 PM
Quote for new furnace. Reasonable? dengle HVAC 16 03-04-2012 07:01 AM
Can't turn furnace fan on from thermostat control cnnd2010 HVAC 0 06-18-2010 10:37 AM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
New Thermostat and Furnace Not Working Right Vegas Resident HVAC 1 12-06-2007 06:42 PM
