Help With Furnace Diagnostic Code - HVAC - DIY Chatroom Home Improvement Forum
Old 10-25-2009, 01:48 PM   #1
Help with furnace diagnostic code
I just replaced the single stage thermostat on my Comfortmaker 9MVX furnace with a Honeywell VisionPro IAQ multi-stage system. I flipped the dip switch in the furnace to use a 2 stage thermostat, but whenever there is a call for the second stage heat, the diagnostic led on the furnace flashes 9 times indicating: High Pressure switch open when should be closed. Any advice on how to fix this?
EDIT: PROBLEM SOLVED SEE BELOW
Thanks,
Ryan
oolowrideoo is offline   Reply With Quote
Old 10-25-2009, 02:29 PM   #2
Rewards Points: 6,652
Did you follow the steps to program the thermostat to recognize the type of Furnace/Air Handler it is hooked up to? Also, did you double check the wiring to make sure connected properly.
Old 10-25-2009, 03:00 PM   #3
GC/Master Plumber/Mech
Rewards Points: 560
The problem you are having has nothing to do with the stat.
You moved dip switch 3 to ON or OFF?
You made a connetion to W2 on the control board?
You can go to www.gocomfortmaker.com and go to technical and look upi the instruction man to diag flash code 9
On 2 stage furnaces with comfortmaker there is two pressure switchs
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 10-25-2009, 03:26 PM   #4
I previously did all of these things... My next step was to check the actual pressure switch. Turns out, I must have accidentaly knocked the hose loose running to the switch. I re-attached the hose, and everything works great. Thanks for the quick replys!
3 - flash code, american standard freedom 90 furnace dfferg HVAC 25 03-05-2012 12:21 AM
Carrier Furnace LED Code 34 and 14 sherjack HVAC 20 11-01-2009 09:45 AM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 02:12 PM
Carrier 58MCA Furnace Ė No Heat (Error 33) zerafah49 HVAC 1 12-10-2008 08:32 PM
Error code flashing on Lennox furnace Head Scratcher HVAC 6 03-27-2008 06:24 PM
