Help with furnace blower problem
The motor is shot. Has a bad starting switch. When it lands on the bad spot of the switch it fails. Change the motor ASAP as it may burn out and fill your house with smoke. Also get the unit checked by a Pro as the heat exchanger may be cracked and unsafe. Get 2 new CO detectors, 1 in the basement stairwell and the other by your bedroom. You need 1" of play in the belt or it burns out the bearings.
"Cut it twice and it is still too short". To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
