Help With Furnace. Bad IPI? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-03-2007, 08:42 AM   #1
Help with Furnace. Bad IPI?
Hello!
First time on the board so thanks in advance!
I have a Lennox G23Q2/3-75-1 unit with the Johnson Controls G776RGD11 IPI. Also, I have a mercury switch thermostat.
It's an odd one here guys and gals. The furnace will run fine for hours and then stop. When it stops I have no 24VAC at the thermostat (measured with meter when the problem first started). When I suspect it has stopped I can verify by moving the fan switch to ON and the fan doesn't come on.
To reset and get things back to normal, I set the thermostat to below room temp, move the fan to ON and wait for a few minutes until I hear the fan start working again.
When the fan starts working again I can move the thermostat above room temp and everything is back to normal. The furnace works like normal and I can return the fan switch to AUTO.
I have noticed that if I don't return the fan to AUTO it will continue to heat and not break. But obviously I don't want to run the fan 24-7. The problem only happens when I return the fan to AUTO.
Any ideas??
Thanks!
Morham is offline   Reply With Quote
Old 11-03-2007, 11:27 AM   #2
Sounds like the sub base on your t-stat is bad. Might be a good time to install a digital t-stat if you are still using an old style.
cjett is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Furnace not firing jax HVAC 5 02-22-2009 12:41 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 05:00 PM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 01:19 PM
Furnace does't start when Fan is 'auto' stepicz HVAC 2 10-18-2005 06:10 AM
