Old 03-04-2010, 07:37 PM   #1
Question
help with forced air wood add on wiring?
So after 10 years of needing a new furnace, I finally took the dive and put one in.
I have a LP gas furnace, with a forced air wood add on that sits right beside it.
Well I got the furnace up and running, but when the wood add-on heats up the plenum on the gas furnace, the lp gas furnace fan motor doesn't kick on like my old furnace always did. Is there a jumper I need to install?
I am sure I need to give you more info, but if you can help, please do.
jay
humboldt is offline   Reply With Quote
Old 03-04-2010, 07:45 PM   #2
Hvac Pro
The new furnace has its fan turned on by a timer on the circuit board when the burner starts. The old one probably had a heat actuated fan control. Doubt if you can accomplish what you want easily. You can turn the fan to ON at the tstat if you have A/C and a fan Auto/On switch. If not you can rig up a switch on the side of the furnace between R and G terminals to manually turn the fan On.
Old 03-04-2010, 08:10 PM   #3
An old Tradesmen
If your furnace doesn't have A/C.
You can install a fan limit switch in the furnace plenum. And just connect the ran side to R and G. it will then run the fan.
If you have A/C on the new furnace. That method won't work real well. As it will also back feed the stat and run the A/C on most thermostats.
Old 03-04-2010, 08:24 PM   #4
Hvac Pro
Swipe the old fan/limit switch from the old furnace and use it.
As Beenthere said, don't use this method if you have A/C or damage can occur.
Old 03-05-2010, 07:20 AM   #5
wow you guys answer fast.
I still have the old furnace, I will look for the old switch.
It did have ac, but the new furnace does not.
thanks a million!
jay
Strange engineered wood flooring install in Philippines (pics) Flt_Simulation Flooring 7 10-05-2009 10:00 AM
Is stripping/sanding to bare wood necessary? hf12358 Painting 13 09-06-2009 10:14 AM
Add-on wood furnace in a small house? Jim Dam HVAC 1 06-24-2008 02:48 PM
Furnace advice - adding a wood burner to forced air CowboyAndy HVAC 4 03-03-2008 11:21 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
