HELP... Forced Air Furnace Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 01-31-2012, 07:02 PM   #1
HELP... forced air furnace problem
forced air heat...honeywell sv9541 gas valve. call for heat... cycles fine..igniter works but burners get no gas. help......
Frank 101 is offline   Reply With Quote
Old 01-31-2012, 07:06 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Take a look at eh bottom panel on the furnace and see if there is a sight glass. Look in the furnace and see if there is a flashing LED count the flashes and post what you find
Also, post brand of furnace and model
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 01-31-2012, 07:13 PM   #3
led is on top of gas valve. code says limit is open.. ohmed out .. showed closed.
Old 01-31-2012, 07:18 PM   #4
it appears that the gas valve got wet thru the top of the cabinet
Old 01-31-2012, 07:19 PM   #5
Rewards Points: 560
post exactly what the code and description of code
Old 01-31-2012, 07:20 PM   #6
Rewards Points: 560
And a Brand and model number would help
Old 01-31-2012, 07:33 PM   #7
If the smart valve got wet it's gone. It'll give you all kinds of bad codes.
hvac5646 is offline   Reply With Quote
Old 01-31-2012, 08:33 PM   #8
Rewards Points: 582
for sure if you are positive valve got wet replace it ....
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Possible Lennox Furnace ignitor problem Paulg1 HVAC 4 11-26-2010 04:38 PM
Carrier Cobra Gas Furnace Problem carriercobra HVAC 13 12-30-2009 11:47 AM
Strange Problem with My Furnace chenjijc HVAC 14 11-04-2009 09:05 PM
Miller G5RA furnace flame sensor problem mpit52 HVAC 3 01-16-2009 10:30 AM
