Old 04-10-2007, 05:28 PM   #1
RFM
Help Diagnose Rheem 80+ - wont start
I have a 10 yr+ Rheem 80+ heater - it makes a transformer buzz when trying to start up. The Draft Inducer Motor doe not turn on. I believe that this is why it wont start - but I dont know if it is the transformer, the vacuum or the motor that is the problem - each seem like easy DIY projects. I took off the Vacuum and sucked on it lightly and the auto igniter and gas started up. I stopped obviously. What can I do? Any help greatly appreciated.....
RFM is offline   Reply With Quote
Old 04-10-2007, 06:51 PM   #2
check for voltage at the draft inducer motor.
elementx440 is offline   Reply With Quote
Old 04-10-2007, 08:17 PM   #3
RFM
Thanks - I took the motor apart and it was pretty gunky - so I cleaned it up, sprayed some WD40 and it works fine now. My quote to fix it was $700 and $5000 for a new furnace since he didnt recommend putting any money into the old machine and then he came up with this great idea to move the furnace and replace all our old asbestos vents for $15,000 ------whoa! dodged a big bullet there!!!
Rheem RXCH-A14 drain pan needed johnd393 HVAC 10 05-14-2007 01:58 PM
Goodman furnace: won't start Guyver03 HVAC 2 10-23-2006 03:25 PM
Girl wants to start wood work, tools? putri Carpentry 8 08-14-2006 07:58 PM
start furnace without igniter??? repairrick HVAC 1 02-24-2006 10:45 PM
