Old 10-29-2012, 05:18 PM   #1
Help diagnose this problem
I have a Payne gas furnace. A few weeks ago, when I cam downstairs in the morning, I noticed it was very cold. The termostat said the furnace was on, but the furnace was not running. My serviceman came out, cleaned the furnace, turned the main switch off and then on, and it seemed to reset. It has been fine until yesterday when the same thing happened. Once I turned the main off and then on, it worked. Same problem happened this morning. He is coming back tomorrow. Any thoughts on the problem, as he could not find anything last time.
Ranger1227 is offline   Reply With Quote
Furnace fan won't switch on--unpredictable intermittent problem arvonon HVAC 3 01-22-2012 05:46 PM
75 year chimney leak problem mstanleyg Building & Construction 10 03-30-2010 01:38 PM
Carrier rep coming to diagnose a problem Faulknertw HVAC 14 07-17-2008 12:25 AM
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
