Old 01-21-2012, 02:23 PM   #1
Help diag. blower motor issue in Lennox furnace
First, this is a great forum. I have read most of the post for the blower motor issue that I am having, but I can't find a solution.
I have a Lennox CB29M-51-2P and the blower motor seems to be dead but is it? After the heat pump has kick on for 30 or 40 seconds, I get both the red and green to light up on the WHITE-RODGERS thermostat. I walk out to the furnace and I hear a medium hum, but the fan is not running. I turned the power off to the furnace and take the door off to expose the blower and such. I turn the unit back on; hear the medium hum and the squirrel wheel is still not moving. I give it a little nudge and the fan starts to spin. BUT, it never runs at the higher speeds; it just keeps running at a low speed and does not move air throughout the house.
What do you think the problem is?
Scott
Model:
CD29M-51-2P
SN: 5804M02390
3/4 HP | 4.5FLA | 1 PH | 60 Hrz
Last edited by partsace; 01-21-2012 at 02:28 PM. Reason: fixed manu name on therostat...
partsace is offline   Reply With Quote
Old 01-21-2012, 02:28 PM   #2
Hvac Pro
bad capacitor. or the motor bearings are seizing. should be able to easily spin it with your index finger ( the one beside the bird ).
Old 01-21-2012, 02:36 PM   #3
Yea, the motor spins just fine. In fact, I need to wait a minute for the motor to stop spinning before I can spin it again...
A: On the capacitor, does this give the motor the juice to spin?
B: Is the capacitor also in-charge of changing the fan speed or give the motor some more juice to spin it faster?
Scott
Old 01-21-2012, 03:06 PM   #4
Ok. Is it best to replace just the capacitor or both the motor and the capacitor?
Old 01-21-2012, 03:27 PM   #5
HvacWiz's Avatar
Originally Posted by partsace View Post
Also, is a transformer the same thing as a capacitor?
No.. it is not
HvacWiz is offline   Reply With Quote
Old 01-21-2012, 03:29 PM   #6
Hvac Pro
the capacitor gives it the extra juice to get up to speed and looks like this one and has a rating in mfds like 5mfd/370 VAC or higher. you can buy them at local electrical motor repair shops or Graingers or cozyparts.com for lennox stuff. under $20.
Old 01-21-2012, 04:43 PM   #7
Mine is 10mfd/370, so that's what I should be looking for, right? Or will a 7.5mfd/370 work?
Scott
Old 01-21-2012, 04:45 PM   #8
Part of the Clover Leaf
NO! Stick with the OEM rating.
hvac5646 is offline   Reply With Quote
Old 01-21-2012, 04:49 PM   #9
Hvac Pro
must be a 10 mfd.
Old 01-21-2012, 04:51 PM   #10
You guys ROCK!
I will give it a try.
Thanks,
Scott
Old 01-22-2012, 04:55 AM   #11
Good luck if you have to buy a new Lennox motor.
bobelectric is offline   Reply With Quote
Old 01-23-2012, 12:42 PM   #12
We have heat! Thanks Yuri for your suggestions on where to get the part! Went to Grainger and got 2 of them for less than $20.00!
Scott
Old 01-23-2012, 03:59 PM   #13
Hvac Pro
yer welcome. thats why the damn things don't last, they are cheap. yrs ago an ac capacitor lasted 30 yrs but it was built like a tank, not anymore.
lennox blower motor help fishon1213 HVAC 11 08-19-2011 02:18 PM
gas furnace whistling when on, not when blower on newguy2010 HVAC 0 12-03-2010 02:58 PM
Portable generator and Lennox furnace joshbloomberg Electrical 7 02-10-2010 11:25 PM
Bryant Gas Furnace - blower sarts and stops montepix HVAC 7 12-24-2009 05:11 PM
Need help with a Lennox Furnace KCDrew HVAC 1 12-09-2009 06:39 PM
