-   -   Help diag. blower motor issue in Lennox furnace (http://www.diychatroom.com/f17/help-diag-blower-motor-issue-lennox-furnace-130865/)
partsace 01-21-2012 02:23 PM
First, this is a great forum. I have read most of the post for the blower motor issue that I am having, but I can't find a solution.
I have a Lennox CB29M-51-2P and the blower motor seems to be dead but is it? After the heat pump has kick on for 30 or 40 seconds, I get both the red and green to light up on the WHITE-RODGERS thermostat. I walk out to the furnace and I hear a medium hum, but the fan is not running. I turned the power off to the furnace and take the door off to expose the blower and such. I turn the unit back on; hear the medium hum and the squirrel wheel is still not moving. I give it a little nudge and the fan starts to spin. BUT, it never runs at the higher speeds; it just keeps running at a low speed and does not move air throughout the house.
What do you think the problem is?
Scott
Model:
CD29M-51-2P
SN: 5804M02390
3/4 HP | 4.5FLA | 1 PH | 60 Hrz
yuri 01-21-2012 02:28 PM
bad capacitor. or the motor bearings are seizing. should be able to easily spin it with your index finger ( the one beside the bird ).
partsace 01-21-2012 02:36 PM
Motor free
Yea, the motor spins just fine. In fact, I need to wait a minute for the motor to stop spinning before I can spin it again...
A: On the capacitor, does this give the motor the juice to spin?
B: Is the capacitor also in-charge of changing the fan speed or give the motor some more juice to spin it faster?
Scott
partsace 01-21-2012 03:06 PM
Ok. Is it best to replace just the capacitor or both the motor and the capacitor?
HvacWiz 01-21-2012 03:27 PM
Originally Posted by partsace (Post 830156)
Also, is a transformer the same thing as a capacitor?
No.. it is not
yuri 01-21-2012 03:29 PM
1 Attachment(s)
the capacitor gives it the extra juice to get up to speed and looks like this one and has a rating in mfds like 5mfd/370 VAC or higher. you can buy them at local electrical motor repair shops or Graingers or cozyparts.com for lennox stuff. under $20.
partsace 01-21-2012 04:43 PM
Mine is 10mfd/370, so that's what I should be looking for, right? Or will a 7.5mfd/370 work?
Scott
hvac5646 01-21-2012 04:45 PM
NO! Stick with the OEM rating.
yuri 01-21-2012 04:49 PM
must be a 10 mfd.
partsace 01-21-2012 04:51 PM
You guys ROCK!
I will give it a try.
Thanks,
Scott
bobelectric 01-22-2012 04:55 AM
Good luck if you have to buy a new Lennox motor.
partsace 01-23-2012 12:42 PM
We have heat! Thanks Yuri for your suggestions on where to get the part! Went to Grainger and got 2 of them for less than $20.00!
Scott
yuri 01-23-2012 03:59 PM
yer welcome. thats why the damn things don't last, they are cheap. yrs ago an ac capacitor lasted 30 yrs but it was built like a tank, not anymore.
