#1 |
Help Determining Age and Tonnage of AC
Hello,
Have old GE unit likely original to the home. House was built in 1978. I am trying to determine the age and tonnage of this system. The current coding conventions that I can find online do not apply to this system. Perhaps someone who has access to Preston Guide or a significant amount of experience can chime in. Model # BTB936A100B2 S/N 250542922 (thinking this is 22nd week of 1979 but maybe not) Any help would be appreciated. |
#2 |
Average Joe/ex-Navy IC3
You are correct on the age. Trane bought them out in 1987.
#3 |
any idea on the tonnage?
#4 |
With the below info, I am going to guess 3 ton.
There are 12,000 Btus per ton of cooling, and air conditioners are sized by every ½ ton. Manufacturers often encode the approximate rating in Btus somewhere in the model number. Therefore it is often simple to scan the model number for a two-digit number that is divisible by 6 and to divide it by 12 to determine the capacity rating in tons. This number can be elusive, as it is not always exactly divisible by 6. Some manufacturer’s systems make this easier than others. To complicate matters, some manufacturers have changed their systems of encoding data over time. General Electric Capacity: Last three digits of model number indicate approximate rating in 1000s of Btus Example: 21TC030A = 2.5 ton Age: Last three digits of serial number indicate date of manufacture, where the first digit indicates the year and the second and third indicate the week Example: xxxxxx241 = 41st week of 1982 http://www.localinspectioncompany.co...les/acdata.pdf Last edited by gregzoll; 06-02-2011 at 09:56 PM. |
#5 |
Professional
its a 3 ton unit
IT IS WHAT IT IS To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#6 |
An old Tradesmen
Help Determining Age and Tonnage of AC |
#7 |
you're not kidding. i had a few problems with it recently that have been fixed. 32 years old and still kicking. cools down my 2400 sq ft house no problem. it is time for a new one but its nice to know i've been able to still keep this one going with very minor investment in a few new parts.
#8 |
#9 | |
An old Tradesmen
Help Determining Age and Tonnage of ACQuote:
Most of those GE's that I see(yep still fromthe 70's), have only ever been looked at when they stopped working(bad contactor, relay, etc) no annual maintanence. they just last. And you won't find a new residential that will last like that with maintainence. Those GE's were built when things were made to last. Today, things are made with planned obsolescence in mind. |
| Display Modes | |
