Help Decide What To Do For A/C & Heater - HVAC - DIY Chatroom Home Improvement Forum
Old 07-04-2009, 02:16 PM   #1
Help decide what to do for A/C & Heater
We recently got a house which is about 30 yrs. old.
It has an end of life heater (central heating system with ducts.) which does not work and has no air conditioning. The condition of the ducts is unknown and I am a newbie , actually worse than a newbie LOL
We are in Northern California Zip 94545.
The house is 2 levels 1600 sq. ft. Upper level is abt 550 Sq. ft.
I am seeking advice on whether we should replace the 30 yr. old heater with a similar heater and get 2 window air-conditioners. (this will be sufficient for our needs).
OR get a central air and heating unit which will be located on the outside.
I would appreciate what the fellow forum members think would be the best course of action.
I would like to keep this house for the next 10 yrs. I have seen 15000 BTU window airconditioners for $300 each and 2 of those (living room + bedroom) can work for our cooling needs with proper installation.
DG2662572 is offline   Reply With Quote
Old 07-04-2009, 02:27 PM   #2
And maybe a fan. If they don't work you can always go to a central unit later.
There is an Economy of Scale issue with two small A/Cs rather than one large one, but that might be outweighed by the advantages of going the window unit route. You paying 13 cents per kwh? How much for propane, NG, fuel oil?
Old 07-07-2009, 08:50 AM   #3
What is your current heat source: furnace, boiler, heat pump, electric furnace?
dac122 is offline   Reply With Quote
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 05:40 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 03:53 PM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 04:01 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
