Old 01-04-2008, 03:54 PM   #1
Exclamation
Help with Crown boiler
I have an old Crown boiler from the 80's that’s tied to a radiant heat system within the ceilings. Just recently the boiler comes on for 2 mins and the pump kicks on as well, but the supply side gets very hot where the expansion tank is at, and the return does not feel warm at all. After 2 minutes the unit shuts off and then tries’s again after another 2 minutes.
Any ideas, do you think the aqua-stat is starting to go bad?
Louie
Louie3888 is offline   Reply With Quote
Old 01-04-2008, 04:02 PM   #2
What is the PSI reading?
redline is offline   Reply With Quote
Old 01-04-2008, 04:04 PM   #3
Exclamation
110 Psi
Old 01-04-2008, 05:22 PM   #4
Union HVAC Tech.
That's not possible, you must be reading the temp.
bigMikeB is offline   Reply With Quote
Boiler Shut Down SassySue General Discussion 3 01-01-2008 12:49 PM
How can I increase PSI in my boiler? (pics attached) drh HVAC 3 12-18-2007 06:26 PM
Boiler Options -Will Boiler be good enough??!! deano54321 Plumbing 2 10-28-2007 07:18 PM
Steam boiler corrosion problem franklopes HVAC 4 11-09-2006 09:02 PM
Crown Caulking Not Sure Carpentry 3 08-18-2006 10:40 PM
