Help!! Could It Just Be The Pilot - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-01-2010, 01:25 PM   #16
Thumbs up
Originally Posted by joetab24 View Post
We got the pilot light on, all of the electrical connections are working, valves are opening but the furnace won't fire up. My father-in-law thinks its the thermocouple but we are having a hard time getting access to it. Should I leave the pilot on?
If the pilot stays lit, then It's DEFINITELY NOT the Thermocouple! As I said in a prior post, the function of the Thermocouple is to prevent the gas from leaking when the pilot does not stay lit, for whatever reason!
spark plug is offline   Reply With Quote
Old 02-01-2010, 07:59 PM   #17
An old Tradesmen
Rewards Points: 6,550
Strange. I've had more then 1 thermocouple that wouldn't open the main valve. But was strong enough to keep the pilot open.
Old 02-01-2010, 09:35 PM   #18
Question
Now, I'm not saying NEVER! But in my (limited) experience it's been (whenever the pilot was lit and the main Gas valve didn't open) either a faulty Main valve or some other safety lockout like a damper or a spill switch.
Old 02-01-2010, 09:47 PM   #19
An old Tradesmen
Yep. I've had stats that would be too restrictive also.
Often, it is the gas valve that is bad.
But it sure does bit if you install a gas valve and 2 to 4 weeks later they have no heat again. And you change out the thermocouple and it works fine after theat for the rest of the heating season.
Old 02-01-2010, 09:54 PM   #20
JohnH1's Avatar
There are two low voltage wires that lead from the zone panal to the gray pump relay on the right rear of the boiler. If you open the gray box the wires should tie to TT termonals. You can jump across thoughs and if the boiler starts it is in the zone panal or zone valves.
JohnH1 is offline   Reply With Quote
Old 02-01-2010, 10:11 PM   #21
Rewards Points: 492
repairman said the damper was preventing the valve from opening 100%. he opened it.
joetab24 is offline   Reply With Quote
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 11:40 AM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 04:29 PM
Urgent! House Cold, NO heat, pilot lit (Lennox) ThatGuy23 HVAC 15 02-05-2009 10:11 PM
heat turns pilot light off tclarkmd HVAC 3 10-12-2007 10:37 AM
hot pilot light supply line dlkk HVAC 1 02-24-2006 06:45 PM
