Old 12-22-2012, 05:37 PM   #1
Help connecting gas fireplace to propane tank
I bought a Charmglow model #CGL250TE gas fireplace at a garage sale this weekend. It had never been used and therefore did not come with a hose or tank. There isn't a manual and I could not find one online. There is a sticker on the back that reads "This heater requires an external regulator to reduce the LP tank pressure to a maximum of 14 inch W.C.". I went and bought an LP tank, a high pressure hose with A 10-psi regulator that has a 3/8" flare swivel fitting (female). One problem is that the fireplace also has a 3/8" female fitting. I went back and bought a 3/8" flare union fitting. I see now that the fireplace fitting is not made specifically for a flared male end. I don't know if this matters or not. I have also read that there is a difference between a low pressure regulator and a high pressure regulator, so now i'm confused if I even have the right regulator. I know that I have to be careful with everything when working with gas. Please help if possible.
davidbisok is offline   Reply With Quote
Old 12-22-2012, 06:12 PM   #2
Roofmaster
Why dont you google that model number and get the manual?
" A lot of men build things, and a lot of things fall down "
Old 12-22-2012, 06:14 PM   #3
Tried that.
Old 12-22-2012, 06:22 PM   #4
There no longer in business.
Try contacting Brinkman.
Old 12-22-2012, 07:58 PM   #5
You'll need either a two stage reg or a second stage reg to bring the pressure down to 10" W.C., and I believe that you can't use a hose to hook up a fireplace ( Id have to double check my code book, but I'm pretty sure it's not allowed). Also, is the fireplace already set up for propane? Natural gas and propane will use different orifices and a different pressure at the apiance valve.
hvac benny is offline   Reply With Quote
Old 12-22-2012, 08:29 PM   #6
When someone actually KNOWS something, please respond to the post, thanks.
Old 12-22-2012, 08:57 PM   #7
Here's what I KNOW:
• your reg is not the proper reg (refer to my previous post)
• you can't use a hose to connect a vented appliance
Here's what I don't KNOW:
• if your fp is set up for NG or propane
• where you're trying to install it
• if you're even allowed to work on gas legally in your area.
Old 12-22-2012, 09:44 PM   #8
It is a ventless fireplace. Is this any different than working on a gas grill? They sell these fireplaces everywhere this time of year and they can be used with propane or natural gas.
Old 12-22-2012, 10:03 PM   #9
You'll want to check your local codes as to if a hose can be used. It depends on a multitude of factors, one of which is it can't pass through a wall. Almost all, if not all gas appliances can be used with either natural gas or propane, but they must be set up for either one or the other. They use different size orifices and different manifold pressure (propane has smaller orifices and higher manifold pressure) because the two gasses have different properties. Hook up the wrong gas and you're going to have trouble.
Old 12-23-2012, 08:19 AM   #10
Chill people here are trying to help you, they don't know your situation unless questions are asked and a good information exchange is made. You'll get your answer hang in there.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 12-23-2012, 12:01 PM   #11
HVAC Tech/Owner
Ventless fireplaces can BE Propane OR Natural Gas and Never can be converted.
Propane for gas grills are very safe because its outside....when you start putting that gas INSIDE your house you should be extremely careful!!! Leak checks, right pressures, right equipment and in our jurisdiction requires a permit even if you are a homeowner OR contractor.
Know a couple of experienced Techs that have no eyebrows (grew back after they got out of the hospital) that have a new found respect for Propane.
Technow is online now   Reply With Quote
Old 12-23-2012, 01:15 PM   #12
Hvac Pro
Not sure they are safe to use and I would not want or trust one in my house. Canada, California and Massachusetts do not allow them period. They can deprive a room of oxygen, give off fumes and can increase the humidity level a lot. The disclaimer they have is you need to have an adequate fresh air supply in to the room, but how many people know or understand that. Like playing with a loaded gun IMO and guns are sold everywhere and legal too.
Tags
fireplace, gas, heat, pressure regulator, propane
varnish on painted propane tank ChatKat Painting 1 07-05-2012 08:12 PM
electric versus propane water heater Jeremy Hillary Boob, PhD Appliances 7 01-30-2012 06:23 PM
Septic tank missing T and badly angled main line? denemante Plumbing 3 11-22-2011 10:29 AM
propane tank size for water heater aladerach Appliances 2 10-02-2011 09:36 PM
Propane Tank buried vs. above ground CheriAlli HVAC 17 11-17-2010 12:05 PM
