Help! Condenser fan comes on but compressor doesn''t
I Have a 4 ton trane unit that once every 1 or 2 weeks decides to stop working. The condenser fan works but the compressor stops working...what could be the problem...? (the inside fan works ok). If I reset the thermostat by pressing the reset button...then every thing works fine (the compressor comes back on). Again this is an intermittent problem...once every 1 or 2 weeks this occurs.
Also, my 4 ton trane is 11 yrs old...just had a 4.5 ton coil with an expansion valve put in by an ac company. (Prior to this the ac wasn't very cold) so they opened up the coil and it was in poor condition (rust, crud build up). Well anyway, it's still not blowing cold and according to them their gauges read that the condenser is fine. However, prior to the new coil, my daytime temperatures coming out of the vent with it being 98 degrees outside was only blowing 69 degrees. After the new coil was put in...it's still only blowing out 69 degrees from the register with it being 98 degrees outside. From what I read on the internet, the temp coming out of the registers should be approx. 55 degrees (I compared this to my sisters house ac temperature out of the registers and her's was about 56 to 57 degrees, pretty close to what I read on the internet). Can anybody give me some insight to what the problem maybe...? Any help would be greatly appreciated.
