Help With Chromotherm III Showing -AC - HVAC - DIY Chatroom Home Improvement Forum
Old 09-02-2008, 10:24 PM   #1
Help with Chromotherm III Showing -AC
My thermostat is showing the -AC which is supposed to mean that it is running on temporary battery power. I am not sure why this just started happening. We have not had any power failures and the fan on the furnace unit continues to run and moving the fan control to auto has no affect. The AC unit does not come on even though the setting is well below the current temperature.
I can move the selector switch back and forth between auto and on for the fan control and the -AC goes away temporarily, the system light comes on and then back to the -AC.
Please help. I suspect something at the unit rather than with the thermostat.
TIA
Mike
mcnoche is offline   Reply With Quote
Old 09-02-2008, 11:17 PM   #2
Electrician
SD515's Avatar
Rewards Points: 504
Try turning off the t-stat (heat/off/cool), and checking that it is properly mounted. Maybe the pin connectors aren't making good contact. Try turning the furnace off at it's switch for 15 or so seconds then on. Sometimes it can reset the furn board. Update us if that doesn't help. Does the furn have a circuit board, and can you see a flashing light?? How many blinks?
Old 09-02-2008, 11:41 PM   #3
Thanks for the reply.
I have tried taking off the t-stat...cleaning what I can and replacing it to no avail. I tried your suggestion of turning off the unit using the switch at the furnace and same behavior. When I turn the switch back on the fan starts up and no control over the AC unit.
I do not see a board with lights...I see a board where the t-stat wires are connected but there are no lights on the board.
Old 09-03-2008, 12:45 AM   #4
HvacWiz's Avatar
Rewards Points: 252
The stat you have is old and outdated, I have replaced many of these stats over the years because of problems you describe. Replace the stat and all will be fine
HvacWiz is offline   Reply With Quote
Old 09-03-2008, 07:48 AM   #5
I am willing to do that but I was unsure if there was anything wrong with the furnace piece before I wasted money on a new t-stat. I was about to call someone out to take a look but would much rather go with the installation of a new t-stat.
Mike
Tags
-ac , chromotherm , honeywell , thermostat
Wall studs showing through sheet rock js1971 Remodeling 7 09-11-2008 05:45 AM
Granite tile and BIG probs with adhesive showing through deeaa Building & Construction 6 07-30-2008 12:44 PM
Chromotherm III Wiring gronk HVAC 4 02-06-2008 04:08 PM
Showing off my basement framing pics...... yummy mummy Building & Construction 103 03-17-2007 02:41 PM
honeywell chromotherm thermostat - help? mkbgriffen HVAC 4 12-26-2006 12:46 PM
