Help Choosing Condenser To Match With Older Rheem Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 05-22-2013, 02:50 PM   #1
Help Choosing Condenser to match with older Rheem Furnace
So I have an 80's rheem gas furnace that works well and has an evap coil in good shape as well so I am leaning on keeping them but the condenser is shot.
Total Rooms - 4
Sqft - 1400
Single story Low ceilings
Hot climate, decent insulation.
Failed condenser was a 3 ton but I wonder if a 2.5 ton or 3.5 ton can also work as well. Any opinions on the tonnage size and if you can use any brand to match with the Rheem airhandler, or does it have to stay Rheem? Any known condensers that are the best value and good efficiency that will fit this setup?
wowor is offline   Reply With Quote
Old 05-22-2013, 09:46 PM   #2
An old Tradesmen
Rewards Points: 6,550
If the indoor coil is from the 80s. then it needs replaced. A 13 SEER won't work well with it.
Quote for new furnace. Reasonable? dengle HVAC 16 03-04-2012 08:01 AM
rheem furnace failure sydefx101 HVAC 8 01-09-2012 06:29 AM
Rheem RGDG-075AUER gas furnace lights intermittently ge01734 HVAC 5 01-01-2012 06:40 PM
Rheem 80% Furnace Short Cycling rlukas79 HVAC 0 12-19-2010 04:27 AM
installing new rheem furnace to old a coil rad488 HVAC 1 10-17-2007 09:07 PM
