Help With Carrier Furnance Which Won't Hold Temp - HVAC - DIY Chatroom Home Improvement Forum
Old 01-24-2011, 08:46 AM   #1
Help with carrier furnance which won't hold temp
I have a 1999 carrier 58PAV furnace and it is not holding the temp from the setting on the mechanical thermostat. If I set it at 68 it will usually drop down to 50 and finally kick in or sometimes I have to manually re-flip the switch on the furnace to start up the blower. Sometimes this starts the furnace up and other times like very early in the am it will not come on. Not sure if we I should start with changing the thermostat or something else? I also checked the led light on the circuit board and the LED light is not blinking continually but it pulses. Not sure what that means either. Also seems to run fine throughout the later morning hours, really a problem at night. Wondering what to do before we call for a service guy. Any help asap would be great - cold Jan day in Chicago! Thanks for your help.
porang is offline   Reply With Quote
Carrier furnance earl kay HVAC 2 01-14-2011 04:49 AM
Help Carrier, Briant Furnance with Variable motor problem ahenderson HVAC 1 12-19-2010 12:07 PM
Carrier Hi 90 Furnance variable speed motor ahenderson HVAC 0 12-18-2010 07:28 AM
Sizing New Carrier 58HDV Furnance PortlandGuy HVAC 1 11-14-2010 12:04 PM
GE Refrigerator doesn't hold temp martinia Appliances 2 12-30-2009 12:09 PM
