Help With Carrier AC Wiring - HVAC - DIY Chatroom Home Improvement Forum
Old 05-24-2009, 09:05 PM   #1
Question
Help with Carrier AC wiring
First off thanks in advance to those that help with this. My wife is calling for the air conditioning, and I can't get it to run properly since I tried installing a new thermostat for the winter. I went back to the old thermostat, but I'm having a fan/ac problem.
My control board has C,Y,GC,GH,R,W in that order. My thermostat, has W, R, Y, G in use. Heater is working fine along with the fan, but when I attach the Yellow wire to GC, fan turns on immediately, but no a/c. Fan runs until I turn off the power to the unit. There are no jumpers involved. If anything else is needed let me know.
So, setup is
control --------thermostat
W white W
R red R
GC yellow Y
GH green G
Bobcat01 is offline   Reply With Quote
Old 05-24-2009, 09:20 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
jumper gc and y on the control board
Old 05-25-2009, 06:29 AM   #3
An old Tradesmen
Rewards Points: 7,760
The wire from the thermostat's G terminal belongs on the control GC terminal.
The Y terminal of the stat connects to the Y terminal of the control board.
You may need to add a jumper from GH to GC on the control board, if one is not already there.
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
wiring aprilaire 700 with carrier infinity chburdette HVAC 14 01-13-2013 04:33 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 07:40 AM
Putting a new Motor in a Carrier Furnace... Wiring issues cbrent HVAC 3 10-08-2007 06:08 PM
