Help With A Carrier 50 HX Heat Pump To Tstat - HVAC - DIY Chatroom Home Improvement Forum
Old 03-16-2012, 09:00 PM   #1
Help with a carrier 50 HX heat pump to tstat
I am installing a honeywell RTH3100C thermostat to my carrier 50HX heat pump and it will only blow hot air with the switch on cool. The compressor kicks on and it blows cold air to the outside of the heat pump. Am I hooking up wires wrong? it's got 2 sets of wires one set has a bundle of 7 wires an the other has 3
bmata12 is offline   Reply With Quote
Old 03-16-2012, 09:08 PM   #2
Coming out of the heat pump I have orange, green, brown, white w/ blue stripe, and a light blue wire in one bundle and the other bundle has a red, light blue and a white wire and the thermostat has E,AUX,Y,G,O,L,R,B,and C connectors..
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
Heat Pump Efficiency Help! horseonthefly HVAC 5 03-16-2012 04:14 PM
carrier 38ycc heat pump blowing fuses headhunter89 HVAC 1 06-20-2011 06:45 PM
new carrier heat pump furnace wont cool home wisjr HVAC 8 08-12-2009 12:23 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 07:40 AM
