HELP: Bleeding Baseboards - HVAC - DIY Chatroom Home Improvement Forum
Old 10-11-2007, 07:31 AM   #1
Angry
HW mixed radiator/baseboard system. Radiators HOT, basboards barely warm at best even with Thermo up high. NO bleeders or valves except one bypass at boiler. Baseboards tapped off main line one side to feed other to return. Can't get air out of baseboards. Need guidance: Where do I put in bleeder for basebaoards? On the return side at elbow just before it goes into floor? IS there any other way to get air out of baseboards? I have pushed pressure up until PRV pops and run water through system with hose attached but air does not come out of baseboards. Thanks.. COLD in Chicago..
Roztom1 is offline   Reply With Quote
Old 10-11-2007, 09:10 AM   #2
Rewards Points: 150
Best location for a bleeder is at return elbow.
However, a vent coupling (as close to return elbow as possible) might be easier to install
P.S. Remember that vent cap has a rubber seal. Remove the cap before sweating and replace it after everything has cooled off.
scorrpio is offline   Reply With Quote
Old 10-11-2007, 03:10 PM   #3
Does vent coupling work better than or is it equal to a bleeder? Thanks
Baseboards around Rounded Corners hgiljr Carpentry 13 09-10-2012 06:08 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
Slow results after bleeding pipes, why? eddiefloyd HVAC 3 02-24-2007 04:54 PM
Colonial Moldings, casings, baseboards sootybuttercup Carpentry 3 10-06-2006 05:51 AM
Need to remove baseboards that are glued and nailed recklessrick Painting 7 10-14-2005 05:20 PM
