Help With Basement Heating Extension - HVAC - DIY Chatroom Home Improvement Forum
Old 12-12-2012, 08:46 PM   #1
Help with basement heating extension
Hey everyone, I'm new to this forum and am currently finishing my basement. I have a baby on the way in 6 months so I am trying to save some cash by finishing it myself. I have done most of the Sheetrock and am just asking that from the duct, ( which is about 8 inches before my wall in which I need a 5" extension that goes through the Sheetrock / insulation. Can anyone direct me to the proper register or something will allow the heat to be coming out from the Sheetrock. Also the proper extension because I am not good when it comes to heating.
Thank you all for answering my question in advance,
Jp
Jperrotta is offline   Reply With Quote
Old 12-12-2012, 08:53 PM   #2
Rewards Points: 582
Jp
picture is needed for us to help you..ben sr
Old 12-12-2012, 09:59 PM   #3
Picture uploaded
There's the image of the wall that I have the opening because I need to somehow get an extension ( don't know pipes so link would be amazing ) and then run it to a registr in which I can cut a hole through the wall and have the heat flow.
Thanks again and I'm sorry if I screwed up , I'm new at this web site.
Jp
Old 12-12-2012, 10:01 PM   #4
Jp
Old 12-12-2012, 10:07 PM   #5
Missouri Bound's Avatar
Where is that pipe in relation to the ceiling, or the floor? Heat distributionis best when it is near the floor. You may be able to elbow down and put in a section of pipe then elbow out to a boot. Insulated ductwork is the best way to go.
Do you want it your way or the right way?
Old 12-12-2012, 10:13 PM   #6
It is almost near the top of of the wall. Almost 83 inches up from floor. Can you recommend a pipe to get as I am so clueless and the workers at lowes / Home Depot are nowhere to be found when I search around. So basically a elbow down and then a pipe leading to near the bottom of the stud then maybe a register out the Sheetrock. ?
Thanks again for Answering in advance
Jp
Old 12-12-2012, 10:19 PM   #7
Jp
Yes, you have the concept. If you have room you can use an insulated flexpipe to a boot in the wall. (5" round to 4" X 10" rectangle angle boot)
Adding a shower in basement with in-floor heating ejanzen Plumbing 1 06-02-2011 07:37 PM
Heating a basement Roland899 HVAC 3 10-04-2010 07:22 PM
Radiant Floor heating in Basement? mfleming HVAC 3 06-10-2008 08:22 AM
Adding radiant heating to basement bath. Need advice. ingeborgdot Flooring 7 05-05-2008 06:40 AM
Tankless Heater for DHW and basement heating clemkonan HVAC 8 09-24-2007 11:43 AM
