Help Assessing HVAC System Before Purchase - HVAC - DIY Chatroom Home Improvement Forum
Old 02-12-2013, 07:31 AM   #1
In the process of purchasing the house I've lived in for the last year. Two story home with separate upstairs/downstairs units. Downstairs unit is older and does a fair job of keeping the house cool in the summer - but not a good job. Is there a way to measurably demonstrate the system is getting old and or needs replacement?
Current owner says system was in when he purchased, so it's unknown how old it is.
lateracer is offline   Reply With Quote
Old 02-12-2013, 07:45 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,144
get a experienced reputable Pro in to check the heat exchanger for cracks and other problems and be there to see it. don't call Joe's heat em and cheatem.
Old 02-12-2013, 07:47 AM   #3
JJboy's Avatar
What's the model and serial number?
Sent from my iPhone using DIY Forum
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 02-12-2013, 08:02 AM   #4
MarginallyQualified
Rewards Points: 2,464
Temperature change: Measure room temp (intake to AC) at X degrees.
Then measure cooled air at (several) outlet registers.
Assume they both are on their last legs and will nee to be replaced within one year. Budget for that work and adjust offer accordingly -or- insist that the owner replace them as part of the sale -subject to inspection-.
Old 02-12-2013, 08:23 AM   #5
Rewards Points: 12,876
If you post the make and model and serial # someone here can tell you how old it is.
Old 02-12-2013, 09:29 AM   #6
Rewards Points: 314
call a pro and have them check the following and make recomendations as to the "fixes" and have them estimate the costs for remediation.
1. subcool and superheat (this is related to how well the system is "charged" with relationship to your install (ie ductwork)
2. delta t (how much temperature change there is as the air passes through your system)
3. static pressue (how hard your air handler is working to move air. most mfgrs state .5 iwc is max)
4. air flow to each room (this relates to comfort and if there is enough air flow to keep each room, based on size, cool.)
5. system size (this relates to manual J and will dictate your max design temps as well as the cost to run your system)
with that info, your professional should be able to advise you what, if any, issues you have and provide you a number that you can use in negotiations with the seller.
bobinphx is offline   Reply With Quote
The Following 2 Users Say Thank You to bobinphx For This Useful Post:
ben's plumbing (02-12-2013), lateracer (02-12-2013)
Old 02-12-2013, 10:43 AM   #7
Hvac Pro
yuri's Avatar
Bobs correct, I did not notice we are talking AC here as mostly it is furnace questions. AC compressors wear like a car engine and lose capacity so an experienced Pro should be able to check the compression ratio and freon level etc. Bear in mind you are buying a used unit and very few sellers will give you any compensation as it is as is.
Advice on selecting HVAC System? elaineycabaney HVAC 4 08-22-2012 08:24 PM
HVAC advice - entire replacement system including ductwork frankleibo HVAC 1 07-25-2012 09:27 PM
What system to purchase for 10,000 sq feet home with seven baths tuckerbergman Plumbing 2 11-04-2011 07:35 AM
New HVAC system in Vermont mrvt HVAC 8 02-24-2011 03:55 PM
HVAC not working properly, zone system terrishan HVAC 1 11-06-2010 08:21 AM
