Help With Ac Ducts - HVAC - DIY Chatroom Home Improvement Forum
Old 06-28-2011, 01:53 AM   #1
help with ac ducts
looking for some help here as i am very confused on ac duct size and placing. I currently have no ceiling in my house and looking to install ducts. what sizes and how many drops do i need?
the black box is where the current a/c is. the numbers are the square feet of the rooms. I am in south florida. Concrete block house. Any help is greatly appreciated!!
Jacob84 is offline   Reply With Quote
Old 06-28-2011, 05:44 AM   #2
An old Tradesmen
Rewards Points: 6,124
A load calc would reveal how many CFM each area needs, which would allow you to size he duct work and determine how many supplies you need.
The Following User Says Thank You to beenthere For This Useful Post:
Jacob84 (07-03-2011)
Old 07-01-2011, 12:09 AM   #3
the bed rooms need 6000 btu each and the main area is 1900btu. how can i go about determining duct sizes and number of drops?
Old 07-01-2011, 05:31 AM   #4
An old Tradesmen
The main area needs 1900? but the bedrooms need 6,000 each?
You select registers that will have the throw you need and a low sound rating at the CFM you need. Generally you limit residential to less then 200 CFM per drop. At 6,000 BTUs it would take an 8" supply for the bedrooms.
You need a real load calc done, and not just guess.
Can you glue to HVAC Ducts tro0925 HVAC 3 03-24-2011 04:31 PM
Asbestos on ducts and duct supply boots DanGauer HVAC 4 08-31-2010 08:09 AM
Replacing Ducts kuwdjones HVAC 4 01-09-2010 05:01 PM
Noisy Ducts jasoncw HVAC 1 10-29-2008 12:51 AM
Using PVC ducts instead of standard ducts robertmazzo HVAC 3 10-05-2006 05:26 PM
