Help With 20 Amp Plug And Heater. - HVAC - DIY Chatroom Home Improvement Forum
Old 11-24-2010, 01:07 PM   #1
Help with 20 amp plug and heater.
NEED: Help with portable electric heaters
Advice needed on portable, high efficiency heaters that would plug into a standard 220 air conditioner outlet (20 amp). We live in an older house and afraid to run too many heaters off the 110 outlets, but the 220 outlets are newer wiring… but we’re having a problem finding a heater that uses that type of plug.
So far, everything we have found has 30 amp requirements and need a much larger plug with heavier wiring. Surely there has to be a heater out there that will plug into a standard 20 amp 220v window air conditioner socket.
Any advice greatly appreciated.
Thank you!
Michael@MasonHolt.com
dearmichael is offline   Reply With Quote
Converting hard-wired baseboard heater to plug Mia Electrical 5 01-02-2010 03:16 PM
Glasshouse heater plug melting stuie Electrical 7 04-21-2009 10:54 PM
Gas pipe to wall heater, can I just put a plug in it? diymonkey Plumbing 6 04-09-2009 06:30 PM
240 v Space heater plug? CooperChloe Electrical 12 02-04-2009 10:57 PM
Baseboard Heater: Can I wire it to plug into an AC recepticle? JBiz Electrical 3 12-01-2007 08:42 AM
