Help With 2 Zone Electic Heat Pump - HVAC - DIY Chatroom Home Improvement Forum
Old 12-07-2009, 05:39 AM   #1
help with 2 zone electic heat pump
2 zone electric heat pump, when zone 1 is on by itself all is good, when zone 2 is on by itself all is good, when both zones are on at the same time zone 1 air flow is good, zone 2 is really weak with air flow.
In the basement there is this duct work that loops around at the furnace with a weighted handle on it, does this control the amount of air that would flow to both zones when both are calling for heat/air?
or what else could be the cause?
Thanks in advance
ctkulig is offline   Reply With Quote
Old 12-07-2009, 06:19 AM   #2
An old Tradesmen
Rewards Points: 7,802
That is the bypass. Its need for when only one zone is calling.
Generally, it should be closed when both zones are calling.
heat pump cut off set point oldswab HVAC 4 12-02-2009 02:09 PM
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 03:05 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
