Hello..my Furnace Is Down Again - HVAC - DIY Chatroom Home Improvement Forum
Old 02-21-2012, 06:04 PM   #1
hello..my furnace is down again
my furnace keeps going out.i keep hearing a puffing sound it will come on and heat then when the fan shuts down i have to hit the reset again.then it will start somtimes..and go out again i had the oil guys here twice480.00 and its still down i have replaced the burner head fan limit and a cad cell then they came again and cut the line outside and put a jointer or bolt on it said it was crimped.sometimes my friend will come and bleed the lines almost everyday says there is air in the lines then it will work for a half a day or a full day the next day it starts all over again.i can not have it replaced until atleast june...any ideas...would be helpful ..my brother said the eye could be dirty but i dont even know what that is...patti
pateez1 is offline   Reply With Quote
Old 02-21-2012, 06:19 PM   #2
Rewards Points: 13,732
Might be a good idea to let everone know what make model and ser# it is. We can not see it from here.
Old 02-21-2012, 06:23 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 2,260
If the lines keep getting air in them then they are what we call air locked. Should not be happening. Did you tell that to the repair guys. Not sure why it is sucking air in. Is the tank reasonably full, ie more than 1/4 full?
Old 02-21-2012, 06:33 PM   #4
thanks..furnace replies
it is a miller furnace in my moblie home.yes i told the service guys..was 3/4 full and still doing it theres a good 1/4 in there now.
Old 02-21-2012, 06:45 PM   #5
as seen on tv
Rewards Points: 150
I would check for improper of leaky fittings and inspect fuel lines, proper nozzle and electrodes. Fuel oil if improperly serviced could be a nightmare
qbert is offline   Reply With Quote
Old 02-21-2012, 06:55 PM   #6
Hvac Pro
yuri's Avatar
Not sure but Beenthere one of our guys may know. Apparently the pump can have a bad seal on the shaft and suck in air and get air locked. I have not seen a Miller in ages but that scenario may be possible?
Old 02-21-2012, 07:10 PM   #7
furnace
Thanks everyone guess I just don't know if I should keep paying the same co.to come out and guess what it could be or call someone else.think I should call another oil co.or Maybe go with hvac speacialist
Old 02-21-2012, 07:13 PM   #8
An old Tradesmen
Rewards Points: 7,356
Yep, a weak pump seal can cause this type of problem. Gets air bound quicker as the tank gets lower on oil.
A weak eye(cad cell) wouldn't cause it to hve air in the oil lines.
The Following User Says Thank You to beenthere For This Useful Post:
yuri (02-22-2012)
Old 02-21-2012, 07:22 PM   #9
furnace
Thank you so much could you give me a idea of what it should cost to replace the seal I think you may be right about leak in pump cud I did find a little kerosene under it a couple weeks ago cleaned it up but haven't seen any since
Old 02-21-2012, 07:27 PM   #10
An old Tradesmen
I don't mess with replacing the seal. I replace the pump.
Old 02-21-2012, 07:35 PM   #11
Ok thank you.it just went out again.I just unnoticed that the line inside from the pump in all crimped and oily.the intake line.that shouldn't be oily u think.
Old 02-21-2012, 07:50 PM   #12
An old Tradesmen
No it shouldn't be.
Old 02-21-2012, 08:13 PM   #13
Hey thanks a lot for taking the time to respond I am going to call in the morning and have that line changed out.
Old 02-21-2012, 08:16 PM   #14
An old Tradesmen
Have them check the pump seal. A new line with a bad pump seal will still give you no heat problems.
Old 02-21-2012, 08:26 PM   #15
Smile
Will do thanks..
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 10:42 PM
