Heil Quaker Shop Furnace Problems - HVAC - DIY Chatroom Home Improvement Forum
Old 12-01-2010, 08:34 PM   #1
Heil quaker shop furnace problems
Hi ,I'm the new guy today,so bear with me. thanks . OK, I have a heil quaker draft induced,propane unit that i heat my shop with and here is the situation .I think the combustion fan relay( essex 192-321040-10661) is bad because the fans will only run when I push the reset button and if I let off everything stops. next when I do press the reset and hold, the igniter will go, and I have 24V at the relay side but nothing at the gas valve ,so now I suspect the old S86H module is toast too(fuse is ok,but it was blown). It should send 24 v to the gas valve ,right? also while looking for a replacement relay,I came across a relay that says 24vdc coil and mine just says 24v and I think mine is ac . Any thoughts or help. I would go buy a new heater ,but like millions of us ,my unemployment ain't paying real well. Thanks again on any help or advice
dirttracker30 is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 08:01 PM
Heil Furnace Won't Turn On ada5011 HVAC 1 11-02-2010 08:29 PM
Heil Furnace Pilot Light Not Igniting shwank HVAC 13 10-07-2010 07:41 AM
Intermittent gas furnace problems dcoz HVAC 1 01-16-2006 10:22 PM
my ac keeps blowing boards on my heil furnace sally HVAC 2 07-23-2005 08:14 PM
